Andrew Tinsley | 18/06/2019 20:46:09 |
1817 forum posts 2 photos | Right, I now have my Arrand Boring head with a 3 MT Taper. I also have the Arrand 2MT Taper. However I am blowed if I can undo the 3MT Taper from the head. There must be a simple way of doing this, but the mind is blank. Andrew. |
ega | 18/06/2019 21:38:02 |
2805 forum posts 219 photos | I believe these are just screwed in with a RH thread. So, essentially, grip the shank and give the head a sharp tap in the appropriate direction. I have done this successfully but don't remember the precise method. The shank could be gripped in the machine's own taper and the tap delivered via a suitably-gripped boring tool. The basic idea is to use the inertia of the shank against some shock loading to the head. I would guess that a boring head shank would be easier to remove than the same make of flycutter shank because of the intermittent action of the latter. Edited By ega on 18/06/2019 22:02:57 |
Mike Poole | 18/06/2019 21:54:53 |
![]() 3676 forum posts 82 photos | When all else fails the shank could be cut off and drilled out, I would regard the shank as expendable if it cannot be removed without risking damage to the boring head. Mike |
Andrew Tinsley | 18/06/2019 22:02:27 |
1817 forum posts 2 photos | Looks as though I may have to cut it off and drill it out. I have tried shock loading the head with the taper fixed and I am afraid I am going to do some damage if I hit the large spanner any harder! Thanks , Andrew. |
ega | 18/06/2019 22:07:34 |
2805 forum posts 219 photos | PS It is possible to phone Arrand and talk to the proprietor's son though I don't know how far he could help. Posting this in the hope of anticipating your attack on the taper and will add the number if I can find it by searching the site. PPS See penultimate post here: https://www.model-engineer.co.uk/forums/postings.asp?th=94955 Edited By ega on 18/06/2019 22:09:53 |
Brian Wood | 19/06/2019 08:41:23 |
2742 forum posts 39 photos | Andrew, They do unscrew, the thread is right hand. Try some heat on the head and a soak of the joint with WD 40 before you try the impact, it might just shock free then It seems a shame to have to resort to drilling it out Good luck. Brian |
Lambton | 19/06/2019 09:17:55 |
![]() 694 forum posts 2 photos | Andrew, I have an old Arrand catalogue dated 2003 in which it states - "Boring heads have interchangeable shanks. Threaded interchangeable shanks are available (see chart opposite) so boring head can be used on machines with different tapers , or if you change you machine, a nrew shank can easily fitted to suit." The "chart opposite) list a wide variety of shanks not just Morse taper ones. Very unfortunately, Arrand ceased trading some years ago probably because of Far Eastern completion Eric |
ega | 19/06/2019 09:57:08 |
2805 forum posts 219 photos | Posted by Lambton on 19/06/2019 09:17:55:
Andrew, I have an old Arrand catalogue dated 2003 in which it states - "Boring heads have interchangeable shanks. Threaded interchangeable shanks are available (see chart opposite) so boring head can be used on machines with different tapers , or if you change you machine, a nrew shank can easily fitted to suit." The "chart opposite) list a wide variety of shanks not just Morse taper ones. Very unfortunately, Arrand ceased trading some years ago probably because of Far Eastern completion Eric Agreed, but I gather they are prepared to sell such remaining items as they have in stock - see my post above for contact. Edited By ega on 19/06/2019 09:57:36 |
old mart | 19/06/2019 22:37:04 |
4655 forum posts 304 photos | Does your MT2 arbor have a male 1.5" X 18 thread? That size seems to be a standard for smaller boring heads. Arceurotrade sell replacement arbors with that thread. If so, the MT3 one could be replaced if you have to destroy it. If there is a flange on the arbor where it screws into the boring head, a couple of flats could be milled in the flange to hold it securely in a vise. Then more torque could be applied to the head.
Andrew Tinsley | 20/06/2019 17:37:38 |
1817 forum posts 2 photos | Thanks everyone, The shank has now been unscrewed! Perversely, I managed to unscrew it by hand. I think all the shock loading and heating persuaded it to surrender to mere unthreading by hand. I can assure everyone that it was stuck tight before. Thanks, Andrew. |
