Boiler issues juliet
michael burton 104/06/2019 19:25:44
126 forum posts
32 photos
Recently purchesed a boiler with a juliet chassis the boiler threads on the backhead for the regulator gland are knackerd.
Studs could be made and ive mad up a dummy set to test this idea and seems it will work ok, now the problem is silversoldering them into place as there is soft solder caulking directly above on top of the boiler shell so puts silber soldering out the question really for the most part.
Could i use a good compound like steam seal and screw the bronze studs once there made in ising said compound to seal them in place the temp trial ones i made up screw in tight with no wobble.
Im mainly wanting the loco for at home with an odd steam up in the garden on blocks etc, i doubt il get a chance to join a club after loosing my licence due to health reasons and can no longer freely get anywere with oit alot of hassle.
So public running is not on a list of things to do so idealy for now need to pass a home hudrulic and steam test for personal use and gain.
This model has been a major help in getting my health back on track for the last month or so and dont want to give up now but as stated dont have the means to get to somewere for helpbto rectfy the problems of the boiler, so having to go it somewhat alone to be able to enjoy it for myself.........
So a effective but simplish repair is whats needed to get me back on track.
Hope you may have a sugestion or advice
Atb mike many thanks for reading mike
Nigel Bennett05/06/2019 13:59:57
500 forum posts
31 photos
Silver-soldering studs into a boiler with any sort of soft solder in it is a Very Bad Plan. Don't do it!
Fitting studs into your boiler should be possible if there's a reasonable thickness of material and the studs aren't too big in diameter. You need good threads in both boiler and stud, and some Loctite 542 will provide an excellent seal.
Once you've fixed it, do a hydraulic test on the boiler to one-and-a-half times working pressure by pumping it up with the hand pump to check all is well before lighting the fire.
I'm sorry to hear about your health issues - I hope you can sort the Juliet out and get it running again.
