allchin 1.5 scale o rings
John Vickery04/06/2019 16:06:57
16 forum posts
Hi Can anyone help in identifying correct size and material grade for glands and piston o rings for use n my allchin 1.5 model. Supplier information would also be appreciated!
Thanks in advance John.
JasonB04/06/2019 17:09:55
Hughes Drew it for Graphite yarn packing so you will have to work out your own hole diameters and depths to get the correct compression on gland O rings and the same with the piston ring grooves. Silicon rings would be best.
Clive Brown 104/06/2019 17:54:39
1050 forum posts
56 photos
When the repeat construction series was published in ME, starting sometime around 1974, Hughes did provide some details for O-rings for piston and glands. AFAIK, the commercially available drawings are still in the original form however.
JasonB04/06/2019 18:19:53
Just checked the text and sketches in the book and as Clive says O rings are mentioned and sizes of recess etc given.
