What's this tool?
Unknown bench tool
Plasma27/05/2019 18:31:07
443 forum posts
Ok, here goes, start the stop watch!
What on earth is this? I'm sure I should know but I cant put my finger on it.
old mart27/05/2019 19:20:08
4655 forum posts
304 photos
It looks like is is a temporary holding down lever. The post goes down through a hole in the bench and an assistant holds the workpiece down while it is cut or planed.
Plasma27/05/2019 20:07:22
443 forum posts
Good idea mart, the flat end has rough file cut striations on it so I thought clamp myself.
But as you say it would need a colleague to hold the clamp while you did the work.
I thought it may be a Jack of some sort.
Mick
old mart27/05/2019 21:49:36
4655 forum posts
304 photos
The bit with the holes in it looks like wood, is there a removable pivot pin?
Plasma28/05/2019 08:18:48
443 forum posts
Yes the upright section is made of wood, the pin is missing.
I cant see it being fixed to a bench but I'm only guessing.
The ends of the wood are worn as if they are the bearing surface.
Regards Mick
Nick Clarke 328/05/2019 10:13:17
1607 forum posts
69 photos
Is it the right way up in the photo?
If you are fitting cups under castors on furniture or spreading a carpet underneath you could stand the wooden stick on the floor and press down on the handle, lifting the metal pad up to singlehandedly fit a cup or carpet under the leg on a sofa or chair?
Just a guess at what it looks like - I know nothing!!.
Plasma28/05/2019 12:36:12
443 forum posts
Nick,
Now that's more in line of my thought process.
I've seen all sorts of bench clamps and such but never one like this, if it is complete then jacking up seems more likely than holding down.
It was found in an outbuilding at Wentworth woodhouse so lifting heavy furniture might be right.
Unless it's for cart or wheel repairs as they had a fleet of them.
Regards Mick
SillyOldDuffer28/05/2019 13:12:35
10668 forum posts
2415 photos
Posted by Plasma on 28/05/2019 12:36:12:
Nick,
Regards Mick
I wondered if it's for positioning a new gate or door being hung on its hinges. Same idea as wheel repairs except it's a bit small for that. It's not meant to take a lot of weight for long, but it would provide fine control for a short time.
It will probably turn out to be a toothbrush...
John Paton 128/05/2019 16:39:03
327 forum posts
20 photos
Removal man's jack for lifting heavy items up and over steps?
peak428/05/2019 23:36:40
2207 forum posts
210 photos
I wonder if it could be part of a version of this cart jack currently on ebay
Bill
