Keith Matheson | 05/05/2019 12:15:39 |
43 forum posts 20 photos | Hi. I have been parting some 19mm across flats stainless and a bit unsure as to feeds and speeds when starting to cut. After the flats have been removed by the tool I found about 480 rpm with ‘sensible’ hand feeding worked well ie cuts well, sounds happy nice crisp sound. However, when I start to part the hex parts sound dreadful as the tool smacks itself into the tool at high speed. I have a Toolco lathe which looks identical to the warco 290. I’m using a rear tool post with a (carbide?) indexible type tool bit (glanze I think). I dribble cutting oil on it with a brush. Basically when it starts it sounds like I’m hammering seven shades of **** out of the tool bit and need to know if I should a. Slow it down initially b keep it as it is or c speed up for the first cutting part. many thanks Keith mm |
ega | 05/05/2019 12:27:44 |
2805 forum posts 219 photos | It's normal for the initial interrupted cut to be noisy. You could consider taking off the flats with a front-mounted HSS tool at slower speed and then move to the RTP at your favoured speed and feed. |
vintage engineer | 05/05/2019 12:28:24 |
![]() 293 forum posts 1 photos | Start slow until the bar is round then treat the same as round bar. |
