Autodesk VRED
Raymond Anderson | 07/04/2019 15:44:25 |
![]() 785 forum posts 152 photos |
John Reese | 07/04/2019 18:04:01 |
![]() 1071 forum posts | I started with Solid Edge. Pretty easy to learn. Later I switched to Solid Works. The user interface is quite similar between the two. I had a little experience with Autodesk Inventor. The user interface was a little different. I tried to use Fusion 360 but the workflow was sufficiently different that I decided to stay with Solid Works. If I didn't own a license for Solid Works I would probably pick Solid Edge.
Raymond Anderson | 07/04/2019 18:31:22 |
![]() 785 forum posts 152 photos | Hi John, although I'm fully conversant with Solidedge. I'm just starting out with VRed rendering software. I hope practice makes perfect 😂 |
