Will they fit Chester DB10 Super?
Brian G | 25/03/2019 19:37:12 |
912 forum posts 40 photos | My son wants to buy one of the self-centring 4-jaw 125mm chucks from Arc and as his new Chester uses the same mounting system (A rotating collar and 3 plug bolts) he wondered if he could use (or adapt) the Arc Backplate? The Chester has a 50mm spindle nose and three 20mm holes on a 75mm P.C.D. Does anybody know if the C6/SC6 dimensions are the same? Thanks Brian |
Neil Wyatt | 25/03/2019 20:38:29 |
![]() 19226 forum posts 749 photos 86 articles | Hi Brian I suggest you contact Arc direct, I'm sure Ketan or ian will be able to check for you. Neil |
Brian G | 26/03/2019 15:51:11 |
912 forum posts 40 photos | Thanks Neil I asked this morning but they don't have the information. Unless anybody with a C6 reads this he will have to make his own backplate. Brian EDIT: Even without a positive result, getting a same-day reply from a supplier has to count as good service. Edited By Brian G on 26/03/2019 15:52:16 |
Brian G | 30/03/2019 19:18:40 |
912 forum posts 40 photos | Just in case anybody finds this in a search sometime, the two are not the same as the Sieg has a larger spindle nose, but I was able to fit a Sieg SC6 backplate to a Chester DB10 Super by making a cast iron sleeve to fit inside the backplate. Lathe Sieg SC6 Chester DB10 Super (2019) Spindle nose 52mm 50mm Plug bolt PCD 75mm 75mm Plug bolt hole dia. 20mm 20mm Brian |
