AJW | 02/03/2019 19:37:50 |
![]() 388 forum posts 137 photos | Got to a stage with my engine before final finishing to attempt a run. I used an electric drill with an adaptor to drive the flywheel securing wedge which seemed to work well with no shaft/flywheel damage although the wedge was marked. I screwed the engine to a piece of MDF which was G clamped to the bench. With the ignition timed for tdc it did a few pops and bangs while I attempted a mixture setup. I found I could only get it to run with the ignition advanced by 30/40 Deg, seemed quite a lot? I was imagining sort of 5/10 Deg? I also experimented with the lift valve in the carburettor. It is suggested that a 'light spring' be fitted to retain it against it's seat, my interpretation of that it seems was too light as I have given my original a bit of a stretching which it seems it needed. My setup highlighted the situation that I need to address with the throttle, it was able to move of its own accord while running and I need to secure the engine down better as it shook all the screws out of the base! Anyway, it runs, some fettling required now!
Alan
Harry Wilkes | 02/03/2019 21:56:33 |
![]() 1613 forum posts 72 photos | Glad it ran video would be nice when your ready H |
Hopper | 03/03/2019 12:58:05 |
![]() 7881 forum posts 397 photos | Nice one. Yes video would be good. And yes sounds like a lot of advance but if it works, it works. What fuel are you using? |
AJW | 03/03/2019 18:49:33 |
![]() 388 forum posts 137 photos | Been trying different springs in the carb on the lift valve, seems to make a vast alteration in running although it still seems to need plenty of ignition advance. Only had it running on petrol at the moment albeit about 6 months old! Seems a lot better for doing a bit of running in and even with my large ring gaps (0.010!) compression appears good. I shall continue with the trials as I am aiming for a nice slow regular tickover! Hope this link works to view it running (excuse the mess!) https://youtu.be/U9TygBTQ0nQ
Alan
