Has anyone experience of increasing the table travel?
The Novice Engineer | 12/02/2019 23:27:44 |
85 forum posts 72 photos | Hi I have had the Mill now for a year or so and love what it can do. Has anyone got any experience of doing a modification like this? |
John Haine | 13/02/2019 08:55:35 |
5563 forum posts 322 photos | What limits the work area Steve? Certainly on my Novamill it isn't the length of the ballscrews, but possibly the position of the ballnut. But you'd need to make sure you had enough engagement of the dovetails.
Emgee | 13/02/2019 16:44:24 |
2610 forum posts 312 photos | Steve If you remove the rear Y axis ball screw cover and shorten it you can get 100mm + movement, perhaps 120mm. Emgee |
The Novice Engineer | 14/02/2019 22:39:14 |
85 forum posts 72 photos | Update I have had a bit of time to take a look under the covers. I reduced the stepper current so I can run to dead stops without causing damage. Then disabled the limit switches. At first glance the Y axis can be extended by modifying the Front and Rear covers to give around ~120mm. Gaining more movement on the X axis is a bit more limited , moving to the left running up to the ball nut is possible to gain ~8mm. Moving to the right the limitation is the stepper motor hitting the case side. There is a Cap Head screw under the Table that is the physical stop, [it appears to hit the Ball Nut housing] removing this an option. Steve |
John Haine | 15/02/2019 08:19:19 |
5563 forum posts 322 photos | Steve, would it help if you had more table area so that you can get workholding clamps out of the cutting envelope? I don't know what size the Emco table is, but over on the Denford forum someone described adding the Sieg long X1 table available from Arceurotrade on top of the Novamill table to give more length and I think a bit more width. Of course it eats up a bit opf daylight under the quill. You could do something similar by using a slab of aluminium or steel, with threaded holes outside the work area for clamps. By the way, you don't really need to reduce the stepper current as you describe, steppers are very tolerant of hitting the buffers if you are moving slowly. Edited By John Haine on 15/02/2019 08:21:02 |
Emgee | 15/02/2019 08:56:56 |
2610 forum posts 312 photos | I have the F1 mill which I believe has the same structure, the mill sits within a walled open top cabinet with a sliding front to gain access. When the table X axis is sent full travel in either direction there is very little space between the table and cabinet side, more on the RH side because of the stepper motor. Work envelope is stated as 200x100x200 (XYZ) and with BT30 quick change tooling suits many needs in the model engineers workshop, but bigger is often better, Arcs cnc mills have greater size envelope but my machine of choice would be a Denford Triac with ATC if I could find a little used machine. Emgee |
The Novice Engineer | 24/02/2019 22:58:03 |
85 forum posts 72 photos | Update 2 After altering the covers on the Cross Slide I now have 124mm Y travel , and shortening the switch actuating rod on the RH side I have 205 X travel. So a useful work area of 204x123 [allowing 0.5 mm at each limit switch before hitting the end stops!]. I have fitted a tapped plate to the table that allows greater flexibility for fixing items down. |
Emgee | 24/02/2019 23:41:31 |
2610 forum posts 312 photos | 24mm is a useful increase in the Y axis, what electronics did you use for the conversion ? Emgee |
Baz | 25/02/2019 11:15:32 |
1033 forum posts 2 photos | Novice Engineer, you have a PM |
The Novice Engineer | 28/02/2019 20:40:27 |
85 forum posts 72 photos | Update 3 Here are some more details of what I modified on the Mill to gain the extra X Y workspace . Y Axis This is where the greatest improvement was made. By removing the front Guard and rebending the front of it I gained around 24 mm of movement on the table [when moving to wards the rear column], I also changed the lower cap head screw that secures the cover over the Z ballscrew on the rear column for a low profile dome head, another couple of mm for little effort. The rear cover [accessed from behind the mill] includes the limit switch actuator for the forward movement [Home position] of the table, this was gently re-bent to allow more movement X Axis There was slight gain on this axis when moving to the left, by shortening the microswitch actuator rod ,~ 8mm removed. [this operates the limit switch under the right hand cover over the stepper motor]. This allowed the stepper motor assembly to come up to the ball nut housing, I set the switch for about 1mm gap here.
The other item to be modified was the cable gland fixing for the stepper motor cables. The gland plate was moved back ~ 18mm with a spacer plate. before I did this when the table moved to the maximum right and back the stepper motor cover would jam against the gland.
I hope this information will be useful to others. I will post some information on the electronics I used as another thread. Steve Edited By The Novice Engineer on 28/02/2019 20:44:49 |
The Novice Engineer | 28/02/2019 21:39:31 |
85 forum posts 72 photos | Here is a shot of the parts from the Emco manual, part 19 is the rear cover that operates the Y axis limit/home switch. |
