Assistance asked from Optics Fundi's please
How to add and graticule/alignment line in a binocular microscope
Joseph Noci 105/01/2019 13:08:06
1323 forum posts
1431 photos
I hope one of the Optics Experts can help me.
I have one of these: - a Binocular microscope - it is in good working order, although I need to strip and clean - there is evidence of dust internally.
The focal point is around 100mm below the bottom lenses. It also has a neat zoom capability which when used still keeps the view in nice focus.
I wish to use this to assist optical alignment of drill cutting edges in preparation of grinding, using the 5C collet arrangement I posted on the MEW forum previously.
A photo of a drill in the collet/square block is last in the photos. How could I go about adding a graticule line in the view, focused at the microscope focal plane? This so that it can be used to center on the drill point, and to align the cutting edges with the line, ie, parallel to either the horizontal or vertical edges of the collet block
I presume the line ( a piece of spiders web??) would need to be stretched across one of the eye piece view lines, maybe at the focal point of the eye piece? - However, if that is so, there does not seem to be enough length inside the device's body to place the line there.. I have spent a few hours digging on the net, but have not found comfort yet...The graticule is fine in one eye view only - the brain seems to sort that.
Please...
Thanks,
Joe
The drill bit in the 5C collet in a square collet block.
A graticule along the line of the Square's vertical edge is desired - can be horizontal or vertical.
Edited By Joseph Noci 1 on 05/01/2019 13:09:17
Robert Atkinson 205/01/2019 13:38:47
1891 forum posts
37 photos
Hi,
the graticule goes under the eypiece see page 31 of
http://www.science-info.net/docs/b-l/BL_Stereozoom.pdf (original sales info too)
More info:
https://www.pyseroptics.com/graticules/technical-guidance-notes/how-to-size-and-fit-an-eyepiece-reticle/
calibration info
https://www.microscopeworld.com/t-microscope_reticle_measuring.aspx
Microscope service manual including cleaning cn be downloade here
https://www.manualslib.com/download/926854/Leica-Stereozoom-7.html
Teardown pictures:
https://www.eevblog.com/forum/testgear/cambridge-instruments-(bausch-lomb)-stereo-zoom-7-teardown/
Lots of graticlues cheap on ebay, most from China.
HTH
They are a nice 'scope I have one and used them for work in the past.
Robert G8RPI
Edited By Robert Atkinson 2 on 05/01/2019 13:40:04
Edited By Robert Atkinson 2 on 05/01/2019 14:43:36
Joseph Noci 105/01/2019 14:06:20
1323 forum posts
1431 photos
Thank you Robert. Just what was needed!
I did a quick, very crude test - inserted a ring of plastic with a 0.1mm diameter copper wire stretched across and moved the ring up and down till the wire was nicely focused and it works well. Now looking for some spiders..
Thanks again!
Joe
Through view - not properly focused on the background text, but the wire is nice and sharp! A taut bit of spider web will work fine for my drill jig.
