Michael Instone | 10/11/2018 19:43:00 |
1 forum posts | just joined, have bought a Denham lathe, need a manual & possibly the gears. Would any other manufacturers back gears fit. All help appreciated. |
Brian Wood | 11/11/2018 12:23:34 |
2742 forum posts 39 photos | Michael, Go to www.lathes.co.uk and look at the splendid archive there. Tony Griffiths, whose site this is, covers a very high proportion of most of the machine tools made and Denham are listed The change gears are listed in the tooth numbers needed but sadly not the DP number, which I suspect just by looking at the photos is 16 DP. Those you can pick up from sales on ebay or from people selling off parts for other lathes. I believe the Raglan Little John lathes had 16 DP change wheels, but I could be wrong. Drummond is another make using that size, but those may be hard to source. If you have even one with the lathe you can establish that parameter for yourself. Count the teeth, add 2 to that count and divide the total by the diameter in inches. The numbers are always whole and even which makes deciding what you have exceptionally easy Welcome to the forum by the way Regards Brian |
Brian Wood | 11/11/2018 14:36:13 |
2742 forum posts 39 photos | I forgot to add, he also does machine manuals for sale Brian |
Keith Long | 11/11/2018 16:22:44 |
883 forum posts 11 photos | Michael Just to save you a bit of frustration, the common change wheels for Drummond lathes are 14 DP NOT 16 DP so you could have problems fitting them to your Denham, depending just how much room there is for gears. Keith (multiple Drummond lathe owner) |
larry phelan 1 | 11/11/2018 16:38:56 |
1346 forum posts 15 photos | Brian, To the rescue,once again ! I dont have a lathe like that,but I found your reply of great interest. Was never quite sure about those DP,s,another piece of useful info to be noted. Thanks once again. Like Tesco says "Every little helps " |
Brian Wood | 11/11/2018 18:49:03 |
2742 forum posts 39 photos | Thank you Keith for the correction. Brian |
