Chris Barrett 1 | 24/09/2018 15:45:42 |
8 forum posts 2 photos | I own a chiming mantle clock - I think it is a Smith Enfield movement, made about 1955. 8 day movement, two keys (one for chimes, hour and half hour, one for time). It used to keep perfect time. Recently it started losing large amounts of time, even though the movement was still working. The displayed time is adjusted by moving the minute hand. What seems to be happening is that the drive to the minute hand is through a slipping clutch - the minute hand is fitted to a long hollow cylinder, and the drive from the movement appears to be a shaft which is a sliding fit into the cylinder. Can anyone suggest a cure? |
roy entwistle | 24/09/2018 16:14:45 |
1716 forum posts | How is the minute hand held on, by a taper pin or a knurled nut ? Roy |
Chris Barrett 1 | 24/09/2018 16:17:13 |
8 forum posts 2 photos | By a knurled nut. The hand has a square hole, which ehgages with a square on the drive shaft. |
Stephen Benson | 24/09/2018 16:46:04 |
![]() 203 forum posts 69 photos | The smiths movement has a star shaped tension spring on the centre arbor which is retained by a pin this pin may have fallen out or there is too much lubrication degreasing the spring may help. |
Chris Barrett 1 | 24/09/2018 17:13:50 |
8 forum posts 2 photos | I can see the star-shaped tension spring, and what looks like a hole in the arbor which may once have held a pin - but there's no sign of the pin. Does it need a special pin, or would some wire passed through the hole do the same job? If I do take the back plate off (I'm a bit nervous about this!), do I need to ensure that both the power springs are wound down fully? Then there are 10 shafts which will need re-engaging to put the back plate back in position. This is new territory for me - all I've done previously is to remove the movement from the case, and then clean and oil the bearings. I've (in my youth) dismantled and re-assembled small bedside alarm clocks - this is much more complex. |
Stephen Benson | 24/09/2018 17:23:22 |
![]() 203 forum posts 69 photos | You should be able to compress the spring with long nose pliers to get a piece of soft wire in to replace the pin without dismantling
DO NOT ATTEMPT DISMANTLE WITH OUT LETTING DOWN THE SPRINGS Edited By Stephen Benson on 24/09/2018 17:26:37 |
Chris Barrett 1 | 24/09/2018 17:28:15 |
8 forum posts 2 photos | Thanks for the advice, Stephen. |
Chris Barrett 1 | 26/09/2018 14:23:03 |
8 forum posts 2 photos | I managed to compress the spring, using a long thin screw-driver held in my left hand - while inserting a piece of wire through the pin-hole in the shaft, using my other hand. Not easy! And now the clock appears to be running perfectly! Many thanks for diagnosing the fault, and telling me how to fix it! Edited By Chris Barrett 1 on 26/09/2018 14:24:36 |
