I bought this item but need parts
Robonthemoor | 23/09/2018 22:35:02 |
![]() 211 forum posts 45 photos | can you ID this rotary table I think it is an HV-6 but don’t know the make! & I need parts & I can according to the intruction book I |
Trevor Crossman 1 | 23/09/2018 22:47:25 |
152 forum posts 18 photos | Hi Robonthemoor, that is a Vertex rotary table shown. Dividing discs are available from RDG/ Chronos and other sellers. Trevor |
Neil Wyatt | 24/09/2018 00:02:40 |
![]() 19226 forum posts 749 photos 86 articles | You need this: Corrected Change Wheel Tables for HV6 Edited By Neil Wyatt on 24/09/2018 00:03:36 |
Robonthemoor | 24/09/2018 09:24:23 |
![]() 211 forum posts 45 photos | Hi Trevor I thought it was an soba so thanks for putting me right, I need the turning handle can one buy them as a part? Do you think MSC or Chronos for best suppling the parts. Thanks for the table Neil I’ve printed it off.
Howard Lewis | 25/09/2018 10:16:03 |
7227 forum posts 21 photos | Would be surprised if you could not obtain Division Plates from Warco, Chester, Chronos, RDG or someone like them. The handle and "fingers" should come as part of the Division Plate package. It might be worth measuring the diameter, and across flats, sizes, to check with your prospective supplier, that the package that you buy will fit your table, rather than ordering and then finding that the handle and plates do not match. It may be worth turning up a short pin (So that the handle can pass over it) to put in a hole behind the "fingers" so that they are not moved inadvertently during indexing. Howard
Howard Lewis | 26/09/2018 21:10:22 |
7227 forum posts 21 photos | Thought that I had already posted this, obviously not. The "birds head" insignia, and the printed info shown, are the same as that on the manual for my Vertex HV6. Buying the Division Plates will include a Handle and the "fingers". If you just want Handle with vernier graduations, you will need to buy that as a separate item. Just don't believe all the data in the chart at the back of the book! It has been pointed out that it contains errors Howard |
Robonthemoor | 27/09/2018 08:25:15 |
![]() 211 forum posts 45 photos | Thanks Howard. |
