Steve Crow | 18/09/2018 19:02:19 |
429 forum posts 268 photos | I've had my Sherline lathe for around 4 months now and I'm hugely impressed. I can use my watchmakers collets in headstock and tailstock and within a few minutes I can be turning 2" bar in a 4 jaw chuck. The screwcutting is a tad laborious but effective with a huge range of pitches, metric and imp. I was worried about stuff like headstock/tailstock alignment but it's adjustable and as accurate as you want to make it. Also, it's easy to make accessories and attachments for. It's getting heavier every week!
Another JohnS | 19/09/2018 14:21:24 |
842 forum posts 56 photos | Steve - well done. Sherline lathes seem like great lathes. A fellow over in the USA made a 1:16th Kozo Shay locomotive (the newer version) on his Sherline Equipment, in about 1/20th the time it took me to build mine in my much larger workshop. John. |
Anthony Prince 2 | 26/09/2018 19:46:07 |
4 forum posts | Steve, Most impressed with the set-up in your photo, especially as you have only had it for 4 months. 1. No motor? So how does the hand-wheel on the spindle work? 2. I like the handled stops on the carriage and the tail stock. 3. Is that a Proxxon drill? 4. Very smart capstain. And vetical slide fitted with inbuilt DTI. 5. Slitting saw to hold the drill clamp. Sherline only seem to supply 1/2" arbor, with the saws only able to cut up to 1/2" depth. I am struggling to find the right solution for a deeper depth. Any suggestions? 6. I am in London. My Sherline is also 4 months old, but I am being rather slow in learning how to use it. Are you close and can we meet? Best wishes, Anthony |
Former Member | 26/09/2018 20:48:06 |
[This posting has been removed] | |
Steve Crow | 27/09/2018 08:53:05 |
429 forum posts 268 photos | Hi Anthony, Thanks for your comments. There is no motor on the lathe as I had removed it for screw cutting before I took the photo. The set up pictured works with the motor on as well. The drill is indeed a proxxon and works well for small milling procedures as well. I don't have a slitting saw, the drill clamp is a bought in item. It's a standard 20mm shaft support for the CNC industry. It's a SK20 and easily available on eBay and elsewhere. The vertical slide is (was) an absolute pile of junk available from a number of well known model engineering suppliers. About the only parts original are the main body and the table. I replaced everything else with homemade parts and added thrust bearings and the capstan for smoother operation. I wouldn't recommend it except as a kit of castings. As for the carriage lock etc, i will post more details later. I'm on a remote Greek island (Gavdos) at the moment and don't have access to my photos. I will post again on my return in a couple of weeks. Cheers Steve |
Steve Crow | 27/09/2018 09:03:28 |
429 forum posts 268 photos | This is the shaft support I use to clamp the proxxon. |
