Here is a list of all the postings Anthony Prince 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Sanding Steel - What thickness can be removed? |
09/10/2020 15:01:06 |
John, How extremely kind of you, but sadly my headstock taper is MT1. Best wishes, Anthony |
09/10/2020 11:00:41 |
Thanks for all your helpful suggestions. It sounds as though using an abrasive is a risky and tedious route, so I won't be attempting this. The idea of grinding the inside of the toolholder is sound. However I already have fittings which fit snugly inside the toolholder and I wouldn't want these to have a looser fit. The adapter is currently held in the chuck by a bar inserted inside an ER20 collet fitted into the MT2 adapter. I thought this would be centred well enough. It clearly isn't. So I think I will go with the other good suggestions from John and Jason and start by creating a MT2 tapered bar in the chuck and using that.
08/10/2020 19:22:37 |
I have: - a Quorn grinding machine with a Ø1" tool holder (actually Ø0.992" id). - a number of inserts for the toolholder to take square tools. - the tool holder does not (yet) accommodate ER20 MT2 nor ER11 MT1 adaptors. - an adaptor Ø1" to MT1; and Ø1" to MT2. These allow their respective collets to be used for sharpening drills. So far so good. - The two Ø1" od adaptors do not fit into the Ø0.992" id tool holder. Their radii need to be reduced by Ø0.004" each. Problem: I am having difficulty in centring these with sufficient precision on my small lathe. Headstock end (4 jaw) better than tailstock end. Question: If I use sandpaper / wet&dry / micro finishing film / lapping film etc - will I be able to reduce the diameter over a reasonably shortish time? Or will it take forever? What are the perceived "cutting rates" for a given grade of paper?
Thread: Sherline |
26/09/2018 19:46:07 |
Steve, Most impressed with the set-up in your photo, especially as you have only had it for 4 months. 1. No motor? So how does the hand-wheel on the spindle work? 2. I like the handled stops on the carriage and the tail stock. 3. Is that a Proxxon drill? 4. Very smart capstain. And vetical slide fitted with inbuilt DTI. 5. Slitting saw to hold the drill clamp. Sherline only seem to supply 1/2" arbor, with the saws only able to cut up to 1/2" depth. I am struggling to find the right solution for a deeper depth. Any suggestions? 6. I am in London. My Sherline is also 4 months old, but I am being rather slow in learning how to use it. Are you close and can we meet? Best wishes, Anthony |
