Tom Senior S type 6" rotary table - backlash adjustment?
mike robinson 213/09/2018 15:37:07
38 forum posts
32 photos
I have been lucky enough to find a Tom Senior S type 6" rotary table in very good condition, other then a bit of backlash which I would like to adjust. I cant find any user manual but the knurled knob on the right side, when undone seems to slacken up the engagement of the worm, but when tightened still doesn't remove the backlash. I guess given its age it's understandable.
here is the link to a photo in my album, but I could not manage to upload the photo without its orientation changing
https://www.model-engineer.co.uk/albums/member_photo.asp?a=49073&p=811742
Any guidance on adjusting the backlash very welcome, a photo of my rebuilt Tom Senior Model E is in the same album, also with a bad orientation
Michael Gilligan13/09/2018 16:53:38
23121 forum posts
1360 photos
Mike,
According to the picture posted by 'RICHARD GREEN 2' on this previous thread: **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=137906&p=1
"A neat arrangement for disengaging the worm is fitted ..."
I may be wrong, but: that doesn't really sound like the knob is an adjuster.
Brian Wood13/09/2018 17:45:50
2742 forum posts
39 photos
Michael,
The link fails to work I'm afraid and neither does the web address, they both bring you straight back to Mike Robinson's post
Michael Gilligan13/09/2018 18:23:46
23121 forum posts
1360 photos
Sorry, Brian ... I had too many tabs open & selected the wrong one blush
This should do it:
https://www.model-engineer.co.uk/forums/postings.asp?th=121855
Edited By Michael Gilligan on 13/09/2018 18:31:30
Brian Wood14/09/2018 09:30:29
2742 forum posts
39 photos
Thank you Michael, information as promised. They are nice looking tables too aren't they, very low profile.
Robbo14/09/2018 11:00:29
1504 forum posts
142 photos
My Tom Senior 6" table is older than yours, and where you have a knurled knob on the side mine has a big grubscrew with a locknut. This definitely alters the relationship of the worm to the wormwheel (but I can't remove backlash entirely). So it seems that the knob is in the right area for an adjuster. Maybe there was a brass plug in there that has worn out/got lost so that you run out of thread before completely tight on the end.
SillyOldDuffer14/09/2018 11:33:45
10668 forum posts
2415 photos
Posted by mike robinson 2 on 13/09/2018 15:37:07:
How much is 'a bit of backlash'? I'm not familiar with your rotary table, but could the backlash you have be normal? As eliminating backlash entirely from a gear-train is quite difficult and may increase wear, it's not unusual to find some backlash even in posh kit.
mike robinson 214/09/2018 17:37:38
38 forum posts
32 photos
Thanks for the responses, I will measure the backlash over the weekend and post my findings for your opinions. I might explore whats behind the knurled nut too..... thanks
John D10/10/2022 22:26:13
37 forum posts
9 photos
Posted by mike robinson 2 on 14/09/2018 17:37:38:
Did you ever get to the bottom of your backlash? I have the same one and stripped it down to clean today. There's a fine line between smooth running hand wheel and not being able to rotate the table a tiny amount by hand. Wondering what your experience has been in use..
