Hakon Halldorsson | 23/08/2018 17:31:48 |
12 forum posts | Good day! Perhaps someone here could either suggest another place to look or another way to narrow down the production year. I'd rather not pick up one that is pre '58 and is no longer supported with spares. |
Robbo | 23/08/2018 19:00:25 |
1504 forum posts 142 photos | Hakon On a lathe of that age the number will be at the tailstock end of the bed on the back of the rear shear, ie the narrow flat vertical that has been machined. It will be SK followed by a number, probably 4 digits. It is not deeply marked so you need to look closely! The front left location (near the rack) is on later lathes. |
Hopper | 24/08/2018 02:24:25 |
![]() 7881 forum posts 397 photos | +1 on that. My 1957 ML7 has the number in the place Robbo describes above at the tailstock end of the bed. Edited By Hopper on 24/08/2018 02:25:54 |
Hakon Halldorsson | 24/08/2018 13:23:27 |
12 forum posts | Thanks for the replies. Just to be clear, as my lathe terminology is not fully developed, is the vertical shear this part? There are a few things I would also appreciate help with that I haven't found online. There is backlash of about .80-.85 when I turn the lead screw handle. Is that a problem or an easy fix? Hakon |
Hopper | 24/08/2018 13:58:05 |
![]() 7881 forum posts 397 photos | Yes, it is the vertical surface of the bed way that the carriage runs on. Number is at the right hand end, so over behind the tailstock. Before you engage the back gear, you need to disengage the driving dog that locks the large "bull" gear on to the spindle next to the pulleys on the main spindle. It has a small allen-head screw there, holding a small sliding block with one or two gear teeth machined into the end of it. You loosen the screw and slide the block outwards then retighten the screw. Check that now the chuck and spindle can spin without the pulley turning. Then engage the back gear by moving the lever. Then start the motor. When inspecting the lathe, check there are no teeth missing off the gears next to the pulley. Backlash on the leadscrew is nothing to worry about. Probably just needs the half nuts adjusting so they engage a little tighter. There is a small screw on teh bottom half nut that does this. At worst case, you can buy and fit two new halfnuts. An easy job. Tumbler reverse lever only changes direction of the leadscrew, for left hand threads. Don't change it while the lathe is running! Main thing to look out for is wear on the bed ways, usually a few inches in from the headstock end. It can be roughly measured with a good straight edge or steel ruler and feeler gauges. Edited By Hopper on 24/08/2018 14:00:59 |
Hakon Halldorsson | 24/08/2018 15:51:05 |
12 forum posts | Thanks Hopper. Good points. It's been in storage, no rust on ways, only a little on the handles, but everything is solid except the lead screw backlash. No teeth missing. I'll check the bed ways. Thanks! Hakon |
KWIL | 24/08/2018 16:02:05 |
3681 forum posts 70 photos | Some of the leadscrew backlash can and almost certainly will be due to the bearing at the right hand end of the bed. This is easily dealt with. Edited By KWIL on 24/08/2018 16:02:32 |
Hakon Halldorsson | 27/08/2018 16:12:26 |
12 forum posts | Well, I took another look and the serial was SK8780 so it is late '58, early '59 model with the updated clutch. I have been sorting out the parts that came with it and would like some help identifying some of the accessories and I took a picture of all of them laid out. New thread for that?
Regards |
Simon Williams 3 | 27/08/2018 16:36:05 |
728 forum posts 90 photos | Hi Hakon, welcome to the (unofficial) Vintage Myford Owner's Club. I've got the very self same model, albeit slightly older and with the original style clutch. Good to see you have rescued it and given it a good home. If it's not too much trouble, I for one would love to see piccy's of what you've got. Can I suggest you include in said pic's one of the left hand end of the bed, to include the RIGHT hand end of the gearbox. There are two (Myford) versions of this gearbox - plus some others retrofitted by others - and the advice you need to set up the gearbox correctly depends on which gearbox you've got, particularly if you have to work it out without the user manual. It's not even obvious that there are two versions! If uploading pictures is something you have yet to fathom out, let us know, it's far from intuitive but somewhere is the users guide to how to do it which could save you some headaches! |
Hakon Halldorsson | 27/08/2018 17:05:43 |
12 forum posts | Hello Simon and thanks for the welcome. Yes, I will upload pictures but assumed it would be easy as there is an image icon here that I planned to use Edited By Hakon Halldorsson on 27/08/2018 17:13:10 Edited By Hakon Halldorsson on 27/08/2018 17:15:16 |
Simon Williams 3 | 27/08/2018 20:06:00 |
728 forum posts 90 photos | Hakon - Unfortunately adding pictures to a psot isn't just a matter of pressing the little camera icon and then browsing your pictures files, you have to upload them into an album on this forum first. I think there is a reference article on how to do this but I can't find it, but this thread gives details. https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=2 **LINK** should (if I've got it right) take you directly there. Good luck, if you need help just say so. HTH Simon |
Nicholas Farr | 27/08/2018 20:22:04 |
![]() 3988 forum posts 1799 photos | Hi, here is the **LINK** about adding pictures. Regards Nick. |
Hakon Halldorsson | 27/08/2018 23:13:23 |
12 forum posts | Ok thanks, I tried (and failed) to link directly to a google photos image, but I came across a site that may make that possible. Here's a test for that, the side view of the gear box: So, did it work like this? |
Peter Sansom | 28/08/2018 12:22:24 |
125 forum posts 4 photos | I have an identical S7 manufactured in 1958, SK8233, one of teh first with the new clutch. Currently in pieces having had the bed ground as a 60th birthday. Just trying to get the carriage machined to convert to a wide bed as per George Thomas. Your paint is in much better condition, mine is cracked and peeling from the climate. Enjoy it, but look for wear in the bed and teh carriage.
Peter |
