turning tooling
sandvik conomant turning tooling
Peter Wellington 223/08/2018 14:46:59
4 forum posts
please help I have 2x Sandvik conomant tgtr-12AM hr179,1-1919AM this tool is right hand triangle insert top clamp and sbpl-12 vl174,2-1919am this tool is left hand square insert top clamp searched internet but found on ebay but not in Sandvik catalogue just need inserts pete
Muzzer23/08/2018 16:09:15
2904 forum posts
448 photos
TBH, you'd need to be looking in a museum, as they haven't made featureless inserts like this for decades. Also, they aren't very hobby-friendly due to the negative top rake, which was all they could manage when inserts had a flat top and you needed front clearance.
Save your money and get a modern tool with proper chipbreaker geometry, modern composition and coating. Put that in a display cabinet instead.
Murray
Jon24/08/2018 20:47:06
1001 forum posts
49 photos
Its the reason i gave nearly all my Sandvik away 8 years ago they make it too hard to decipher bog standard tip profiles used by other quality producers.
They have their own part numbers which only translates to Sandvik. Rest assured the tips that will go in them (10's of profiles and grades) are off the shelf and still current meant for aluminiums and non ferrous.
https://www.sandvik.coromant.com/en-gb/products/pages/turning-inserts-grades.aspx See what i mean it leaves you non the wiser.
Will find various other tips will go in but may have a through hole.
