Myford ML10 pulley diameter
Manfred Baer05/08/2018 20:28:39
15 forum posts
I wonder if someone can help me with the size (diameter) of the motor pulley and the countershaft drive pulley for a Myford ML10 lathe?! Thanks, Manfred
Jim Guthrie06/08/2018 12:58:22
128 forum posts
5 photos
Mine is the original ML10 bought in 1973. The motor pulley is 2 1/2" overall diameter and the countershaft pulley is 7" overall diameter. The depth of the V belt groove is 7/16".
Jim.
Edited By Jim Guthrie on 06/08/2018 12:58:59
Manfred Baer06/08/2018 17:23:09
15 forum posts
Jim, many thanks for the reply.
Mine is an original ML10, too. I bought it brand new in the early 90's in Cardiff. For unknown reason my lathe (roller bearing headstock) was packed with the Speed10 set of pulleys. I collected the lathe in person and discovered the mistake only after returning back home to Germany. Well, the Speed10 pulleys are on it and since then I avoid the 3 top speeds. No real problem.
Just recently I got the information that using the 2 original single groove pulleys makes the lathe running smoother and more quiet. This should come from the larger diameters of the ML10 pulleys. Now I'm thinking about a conversion back to the original configuration.
Manfred
