James Alford | 02/07/2018 22:44:20 |
501 forum posts 88 photos | Good evening. I am getting muddled, so should appreciate any help, if possible. If an engine and gearbox which is normally matched to an axle with a differential with a ratio of 3.23 and 10" wheels (tyre OD of 19.1" I cannot work out whether the larger wheels and 5.25 differential will result in the engine over-revving, under-revving or whether there is likely to be little difference. Any suggestions? Regards, James. |
Martin W | 02/07/2018 23:13:14 |
940 forum posts 30 photos | James The 19.1 tyre OD with the 3.23 ratio for 1 rev of the input shaft will move 18.58 in. The 25.6 tyre with the 5.25 ratio for 1 rev of the input shaft will move 15.32 in. The difference between the two is 18.58/15.32 = 1.21. So the drive shaft will be rotating 1.2 times faster for the larger wheel with the 5.25 ratio compared to the smaller wheel with the 3.23 ratio to achieve the same speed i.e. if for the smaller wheel arrangement at say 30 mph the engine turns at 1000 rpm then with the larger wheel arrangement it will have to run at 1210 rpm. I think this is correct and hope it helps. MartinW PS Potentially better acceleration but lower top speed for the 25.6 tyre with the 5.25 ratio diff. Edited By Martin W on 02/07/2018 23:15:05 Edited By Martin W on 02/07/2018 23:18:35 |
James Alford | 02/07/2018 23:35:14 |
501 forum posts 88 photos | Martin. Thank you for the prompt reply. If I understand your reply correctly, am I right in thinking that with the larger wheel, the car should accelerate more rapidly, but have a lower top end than with the smaller wheel: well, at least in theory? James. |
Martin W | 02/07/2018 23:46:20 |
940 forum posts 30 photos | James That's the way I see it from the method I used to determine the difference between the two set ups. The driven shaft will have to turn faster to maintain the same speed with the 5.25 ratio and 25.6 OD tyre. It would be similar to running in a lower gear all the time. Cheers MartinW |
Martin W | 03/07/2018 00:14:52 |
940 forum posts 30 photos | Double post Edited By Martin W on 03/07/2018 00:15:34 |
James Alford | 03/07/2018 07:32:51 |
501 forum posts 88 photos | Martin. Thank you for the confirmation. This is what my logic told me, but my late night calculations did not confirm it. High revving for the slightly better acceleration will be fine in preference to under revving and struggling to pull in top gear. Regards, James. |
