Mondays boot fair finds
William S | 09/05/2018 11:53:47 |
![]() 80 forum posts 335 photos | Hello all The nearby car boot sale turned up a few bits for the workshop;
A pair of large V block stirrups (is that the right name?) No makers name so could they be apprentice pieces? There was no sign of the V blocks so redundant I suppose, still might be useful. Also a Chinese 80mm self centering 4 jaw lathe chuck minus the other set of jaws, for £12 might come in useful one day, would have to come up with a backplate on the Myford but it does fit the Axminster sc2 mini lathe with minimal run-out so might remain on there just in case! Then there is this item, was wondering if anybody can shed a light on its use would appear to be a jig to hold something but what I am unsure; The pin is spring loaded the vertical line is a V And this is the clamping knob on the rear of the tool. It looks to be home made for quite a specific task, it came from the same box as the drill chuck and V block stirrups if that helps in anyway. There was also flexispeed meteor 2 lathe there in quite original condition with the vertical slide, fixed steady, 3 4 way tool posts, little drill chuck and a few other bits, didn't ask about the price but I can think it wouldn't of been cheap if they had done a bit of research! (they were also dealers) Then there was a G.Boley watchmakers lathe in its box and looked quite complete. However the £400 asking price is going to put quite a few people off. Many thanks for reading and any ideas on that unknown part would be good. William |
Neil Wyatt | 10/05/2018 18:36:01 |
![]() 19226 forum posts 749 photos 86 articles | Interesting one, William. It looks like the long bar clamps a small, cylindrical object in the vee, at a position decided by the stop and the angled (scriber?) marks or aligns with it. Clearly made to a high standard for a specific and presumably quite precision job.
John McNamara | 11/05/2018 14:48:52 |
![]() 1377 forum posts 133 photos | I think the angled sides are a clue. Maybe a jig for grinding facets on some sort of cutting tool? Edited By John McNamara on 11/05/2018 14:49:20 |
