balancing article issue 4586
duncan webster05/05/2018 12:44:06
5307 forum posts
83 photos
Unfortunately the printers have had there usual difficulty with superscripts, and so the equations at the top left of page 708 are badly misprinted. They should read
The rotating rotating force on the front axle would be 890 * 402 / 106 * 1.414 = 2.0 N = 0.45 lbf
The rotating rotating force on the rear axle would be 1942 * 402 /10 *1.414 = 4.4 N = 0.99 lbf
and the reciprocating force to the loco is 3852 * 402/106 * 1.414 = 8.7 N = 1.96 lbf
Let's hope that this site can cope! Don't know why it has changed the font size, I just cuat and pasted out of the original
Edited By JasonB on 05/05/2018 16:13:05
Edited By JasonB on 05/05/2018 20:48:48
duncan webster05/05/2018 20:36:10
5307 forum posts
83 photos
Just noticed that even that isn't right, the last equation should be
let's see if that works, cut and pasted again from the same original
SillyOldDuffer06/05/2018 11:22:35
10668 forum posts
2415 photos
Enjoyed reading this article over breakfast and it was helpful to know in advance which printed formula had been mangled.
Despite struggling with the maths (worthwhile) I found several points of other interest in the article. For example, Duncan mentions 'I am not aware of anyone measuring hammer blow on a model'. Now there's a challenge! My first problem is I can't even imagine how it might be done at full size! How is hammer is measured in practice, or is it always calculated?
duncan webster06/05/2018 11:43:38
5307 forum posts
83 photos
The first post seems to oscillate between getting the formulae right and getting them wrong. Does this site have a mind of its own? (Just spotted, it's been altered by JasonB)
as to measuring hammer blow, the LMS set up a loco (Black 5 I think), coupled it to something immovable, applied grease to the track and ran it at high speed. At some very high speed it started lifting it's wheels off the track. I suppose they could have strain gauged the bit of track, but I have no concrete info. There is mention in the Bridge Stress Committee of instrumented track, but I'm not sure how that works, you'd have to be lucky to get the wheel over the right bit of track at the right time. Much more likely is that they weighed the relevant bits and pieces and worked it out. I believe major builders had balancing machines similar to that in the photo.
I have read somewhere that the model gas turbine builders have balancing machines. All you need (all!) is two bearings set on force transducers and a means of capturing the data. As it doesn't really matter in model locos I'll stick to weighing and calculating. If you set each driver on an axle rolling on horizontal knife edges you can measure the initial out of balance quite easily.
There are many many locos out there which just run without messing with this arcane stuff, but it keeps the grey matter going trying to work out the effects
John P06/05/2018 21:23:55
451 forum posts
268 photos
Posted by
duncan webster 06/05/2018 11:43:38
Hi Duncan
Read through your interesting article a few times ,still trying to
get to grips with it.
Adding weights to simulate the motion gear and then balancing the
wheels as a set seems to be what you wish to do.
The gas turbine balancers are a much more simple thing to do as
the objective is to reduce the imbalance to a small amount as possible.
The photo here is my two plane balancer ,the imbalance is displayed as
a sine wave on an oscilloscope but has no values .Balance is achieved
by adding weight to the light side (plasticene) and then removing metal from
the opposite side,You may be able to see some metal scraped off
the blades of this milled from the solid compressor wheel.
This wheel needed only a few milligrams off the front plane and a little
more off the rear to balance.
The pickup coils are from an old washing machine solinoid valve and
some neodymium magnets ,the signal is very small using an op amp
gives a usable signal ,the balancer sits on the table of my mill which weighs
in at about 500 kg but will pick up normal footsteps on the concrete floor
in the workshop from 12 feet away.
Most of these balancers seem to use piezos for the sensing , have
used them they can be very sensitive and can pick up a lot of unwanted
signals ,the quality of bearings can have some considerable influence
on any displayed signal and can mask the information that you need.
Some useful reading at www.universal-balancing.com on this site a balance tolerance calculator and some additional balancing info at www.turborebuild.co.uk
Tim Stevens06/05/2018 22:08:58
1779 forum posts
The effect known as hammer blow is, as I understand it, caused when the upwards force on the wheel is enough to overcome the down force from the spring, at a particular position of the parts, repeated each cycle. So, it is a repeated blow (not like leaping a hump-back bridge) and the hammering is when the wheel comes down back into contact with the rail. So, a high speed camera ought to be able to detect it, as would a microphone, I expect. Or even a small boy hanging by his toenails from the name plate.
The particular difficulty which I find interesting - of balancing steam locos - is the fact that generally the pistons move 90 degrees out of phase. This means that any unbalanced forces cannot be countered by those on the other side, as when one piston is at a dead centre, the other is (about) half way and max speed. As a result, they tend to cause rocking of the whole engine from side to side. If this happens at the resonant rocking frequency, the cup of tea carefully balanced in the cab will fly out of the window, followed by the fireman's hat. Other effects are also available.
The only 'answer' I have been able to find (apart from clever damping of sway) is to use three cylinders, working on an inboard cranked axle (no con-rods to the wheels, then) and possibly wheels linked by rods at 180 degrees. I suspect that finding room for the valve drive makes this difficult.
If there is to be a follow-up article, this might make a useful further topic, I suggest.
Cheers, Tim
duncan webster06/05/2018 22:13:51
5307 forum posts
83 photos
That is truly awesome. Notice I put an exclamation mark after the 'all'. Crying out for a write up in ME. Not clear how you rotate the disc, and is there a readout of angle so you know where the imbalance is rotationally?
I suspect what you have is a 'soft' balancer where you let the spindle move and measure the movement, as opposed to a 'hard' balancer where you stop it moving and measure the force it takes. I'd be interested in more details of your motion sensors as well. I've thought of using record player heads before, but never got any further than thinking
John P07/05/2018 10:55:01
451 forum posts
268 photos
Hi Duncan
The first photo shows here this arm has a IR sensor which
moves in an arc of about 280 deg on the axis of the
item being balanced ,a felt tip line on the component
shows a pulse on the oscilloscope display.
Superimposing this on the sinewave generated by the motion
of the spinning component the arm is rotated to co-inside with
the peak or trough of the wave.
The rotor is driven by a small dc motor and a flat turntable belt,
the speed is adjustable .
In practice this rotor seen in the second photo would be spinning in
an anticlockwise direction ,the motion of the support bearing
moves to the right to provide a positive going wave .
A small weight is attached and the arm adjusted to the peak
of the positive wave.The rotor is stopped and the felt tip
mark is aligned with the sensor,if the speed of the rotor
is above resonance the weight will be at about the 9 o clock
position ,using a pointer to mark this position the weight
is removed and the rotor set spinning again ,adjusting the
position of the sensor to set the position of the wave the rotor is
stopped and the mark aligned again ,the position of the heavy or light
spot will be by the pointer depending whether the mark is aligned with
the peak or the trough of the wave.
Have sent you a PM.
This is as you suspected this is a soft balancing machine ,Joseph Noci
posted this thread which contains reference to a hard balancing
setup which may be more suitable to your application.
Joseph Noci 1 02/12/2016 13:47:16
A Hi-Speed Sensitive drill press.
Another JohnS07/05/2018 16:31:06
842 forum posts
56 photos
Duncan;
Just a note that 4585 came today - looking forward (very much) to reading 4586, sounds like an interesting article, something to (as you say) keep the grey matter in check.
There's so much to learn, just not enough years to learn it in...
Tim - I did a bit of time (as I was was licensed to) in the cabs of large steam locomotives, and the clockwise sway of the locomotive's cab was noticable, especially on a 2-8-0 on a slowish-uphill drag. It was also told to me by a now deceased fireman/rail enthusiast that, on a Canadian 4-6-2 that we used to run in excursion service, that the trailing truck did the most work of any axle on that locomotive.
Again, interesting stuff; authors may not get much feedback, but interested novices like myself would certainly appreciate the articles.
John.
Tim Stevens07/05/2018 16:42:49
1779 forum posts
For those who are not mathematically inclined, there is another way to show what happens as you try to balance a to-&-fro motion with a round-&-round one. It can be produced on your knee as you sit at home - and it relies on nothing more complicated than paper, pencil, a ruler and a pair of compasses.
If there is interest in this as a way to understand better, please let the editor know and I will cobble something together.
My idea has appeared before, in the esteemed magazine Motorcycle Sport, in the mid 1970s, but as I wrote it then I can give myself authority to do it again.
Regards, Tim
duncan webster08/05/2018 12:35:44
5307 forum posts
83 photos
As I said in the original, allowing for the fact that the various bits and pieces are not in the same plane gets more complicated, and is verging on text books, which might be out of place in ME. I could try to put something together, what does the forum think? The editorial team would have to sharpen up their act on printing formulae. For a loco built somewhat along the lines Tim was suggesting see
although this had 2 'motors' each with cranks at 90 degrees. This would make a super model, just drop out the motor/axle assembly from below if you wanted to work on it. Just a small point, con rods at 180 degress doesn't work as they are both on centre at the same time
Tim also offered another way of demonstrating reciprocating balance, bring it on says I.
Edited By duncan webster on 08/05/2018 12:40:52
SillyOldDuffer08/05/2018 14:04:20
10668 forum posts
2415 photos
Posted by Tim Stevens on 07/05/2018 16:42:49:
For those who are not mathematically inclined,...
Regards, Tim
Yes please Tim!
Maths is a tremendously powerful tool if only I understood how to use it properly. Anything that helps me understand balancing better will be read with interest.
Not sure what the ideal balance between numerate and practical articles is. Personally I'd like to see a tad more theory in the magazines, but then I'm a bit weird.
