Gerald Legg | 22/03/2018 12:30:24 |
1 forum posts | I have a Victorian microscope whose rack and pinion have been abused. The rack is fine but the teeth of the pinion have been virtually stripped. Could anyone make a replacement or suggest a source? The pinion is 6.6mm in diameter with 15 teeth. My lathe is too big (and ex War Department one used to turn artillery shells). Any help would be very gratefully received. Thank you. Edited By JasonB on 22/03/2018 15:12:52 |
Brian Wood | 22/03/2018 17:39:58 |
2742 forum posts 39 photos | Hello Gerald, Is this a straight cut or helical pinion? It will make a big difference to finding a volunteer. Regards Brian |
Bob Stevenson | 22/03/2018 19:13:08 |
579 forum posts 7 photos | Find a small piece of HSS,..or even silver steel and grind it down until 'perfect' fit in the teeth of pinion...........Put brass rod in lathe and turn down to 6.6,...then mount the tool and use saddle to 'plane' the teeth into the brass...which is relatively easy on brass, but don't take too big cuts.......... Use a change wheel/improvised detent on spindle to 'index' 15 divisions
Alternatively, try the massive clock sundries catalogues from the usual suspects such as Walsh, Cousins, or Meadows & Passmore They probably have something that will serve or can be adapted Edited By Bob Stevenson on 22/03/2018 19:15:54 |
john carruthers | 23/03/2018 08:32:43 |
![]() 617 forum posts 180 photos |
Edited By john carruthers on 23/03/2018 08:33:48 |
