duncan webster | 26/10/2017 11:18:49 |
5307 forum posts 83 photos | There was a bit of discussion a bit back about governors. Going through a pile of ME's to scan the good bits prior to giving them away I've come across Tubal Cain's articles. If anyone wants a copy send me a pm with your e-mail address |
Howard Lewis | 26/10/2017 18:17:38 |
7227 forum posts 21 photos | Many early steam engines, (and I C engines) were controlled by Watt or Pickering governors, operating a throttle valve. Some of the early I C engines had governors which were pretty crude. (The simplest was just a weight in the linkage which operated a wedge to either hold open a valve, or to prevent it opening. The slightly more sophisticated carried weights within the Flywheel which did much the same thing, or disabled the ignition system. It was the advent of higher speed engines which brought a requirement for more sophisticated and accurate mechanisms to control speed, leading to governors capable of providing isochronous control. The ultimate are the electronic governors which will now control speed to within a few tenths of an RPM. Again, a monument to the skill of Engineers Howard |
Thor 🇳🇴 | 27/10/2017 05:26:21 |
![]() 1766 forum posts 46 photos | Thanks Duncan for your kind offer. Thor |
