Broken Myford 1st Stud Gear Nut
Peter Wood 517/10/2017 21:50:45
94 forum posts
11 photos
I have broken the hollow bolt which retains the 1st stud gear on my Myford Super 7.
Can anyone advise me what sort of thread it is so that I can fabricate a replacement.
Thanks.
Peter
Edited By Peter Wood 5 on 17/10/2017 21:51:48
Lambton18/10/2017 09:17:28
694 forum posts
Peter,
The bolt you refer to is not hollow. It is a special with a head designed to engage in the slot in the quadrant to prevent rotation when tightening the nut. The shank is 1/4" diameter with a short length of 1/4" BSF thread. Not hard to make from a decent piece of steel eg from a large high tensile bolt
Alternatively try one of the suppliers of second-hand Myford spares on EBay or if all else fails a complete stud assembly is available from ."New" Myford.
Eric
Nick Hulme18/10/2017 09:27:22
750 forum posts
37 photos
The two change wheel studs on my Super 7 banjo do have a blind bore with a cross hole to allow use of an oil gun to deliver oil to the bearing surfaces,
- Nick
Peter Wood 518/10/2017 10:39:42
94 forum posts
11 photos
Eric and Nick.
Thanks for your replies. By trial and error I found that a 2 BA oil nipple fitted perfectly. The 2nd change gear stud is also fitted with an oil nipple.
The bolt was probably used instead of a nipple as it locks the retaining lever for the second gear. Anyway I will contact Myford to see if they do spares.
Thanks again.
Peter
KWIL18/10/2017 11:02:48
3681 forum posts
70 photos
Yes they do, Part 209 on diagram, A 2329/2 Gear Stud £24.00
