Micro Bearing Question
David Cambridge | 15/10/2017 09:00:15 |
252 forum posts 68 photos | Hello all
I need a bearing that will run at about 15000 RPM, for extended periods, be tricky to get at when running, and on a shaft of 6 mm diameter. I’m a bit stuck.
Should I
Give up ?
Make a phosphor bronze bushing ?
Buy a good quality micro ball race ?
Thanks!
David
Edited By David Cambridge on 15/10/2017 09:00:35 |
Clive Hartland | 15/10/2017 10:02:04 |
![]() 2929 forum posts 41 photos | Forget the bronze bushing, I doubt it will stand 15,000 rpm. Search for high speed ball bearings and you may find they are only have 5 ball bearings in them. They only need a small amount of lube. oil not grease. |
mgnbuk | 15/10/2017 10:23:44 |
1394 forum posts 103 photos |
How about ceramic bearings ? A quick Google for a spec on a ZrO2 696 bearing from one manufacturer gave an operating temparature of up to 250 C and 12000 rpm when oil lubricated - other makes may give different specs. & alternative lubrication regimes may help increase the operating speed. HTH Nigel B |
