Howard Snowden | 08/09/2017 21:14:00 |
21 forum posts 3 photos | I am looking for advice regarding the BR Std loco vacuum ejector which is fitted on the left hand side of the smoke box. The steam exhaust from the ejector is directed into the smoke box via a 90 degree elbow. Can anyone tell me where this pipe is connected to inside the smoke box, or is it just vented to inside the smoke box? Thanks Howard
Edited By Howard Snowden on 08/09/2017 21:17:12 |
Bob Youldon | 09/09/2017 11:22:06 |
183 forum posts 20 photos | Hello Howard, Without the benefit of a works drawing to hand, I'm certain with the BR standard single chimney locomotives a pipe was fitted inside the smokebox from the elbow and connected with the petticote casting to vent the exhaust into the chimney; on some double chimney locomotives (class 4 4-6-0s) the exhaust had it's own seperate port through the top of the chimney casting. Regards, Bob |
Howard Snowden | 09/09/2017 21:32:24 |
21 forum posts 3 photos | Thanks Bob, I would have thought that it must be connected to the chimney some how and not just vented into the smokebox. |
julian atkins | 09/09/2017 22:03:37 |
![]() 1285 forum posts 353 photos | Hi Howard, If the ejector pipe went just into the smokebox it would destroy the smokebox vacuum. It must go up the chimney without affecting the smokebox vacuum or the smokebox draughting and as Bob states there are various ways to achieve this. It would be interesting to know whether your loco is the double chimney or single chimney type that Bob hints at. The double chimney type is far better. Cheers, Julian Edited By julian atkins on 09/09/2017 22:04:13 |
Howard Snowden | 10/09/2017 12:21:10 |
21 forum posts 3 photos | Thanks Julian, I am building a 71/4" 9F, double chimney version. Regards, Howard.
