shand mason
plans
tom hardy28/05/2017 11:42:32
30 forum posts
i have started building a shand mason fire engine westbury plans i have the 6 sheets of drawings and the castings. on sheet 4 there is a syphon box which appears from the photos to fit on the rear of the steam box. i cannot work out what it does and where do the pipes from the bottom of this box go to . some photos on the net show the pipes going to the crank bearing the drawing only show 1/16 oil holes no pipes
where can i buy the suction and discharge (fire hose) or what can i make them from
regards tom hardy
ian j28/05/2017 19:13:37
337 forum posts
371 photos
Hi Tom.
You are corect the box contains oil and 3 pipes go from the bottom and go to the crank bearings, if I remember correctly I put string in the pipes to act as wicks.
This how I made my suction/discharge hoses:
I length of plastic tube ( car windscreen washer type)
slide a rod of steel/brass down the bore.
mounted on the lathe, one end in chuck other supported by a tailstock centre
then set the lathe to say 8 tpi screw cutting
then as if winding a spring wrap a thin wire along the length of the tube
remove from the lathe cover with white heat shrink sleeving and heat using a hot air gun.
The end result looks really good with the wire looking like the ribs of the hoses.
Hope that makes sense?
If not I will try again.
Do you have a copy of the build article from Model Engineer mag?
If not I have scans of them & could put them on disc for you.
There are some photos's of mine in my album
Ian
Edited By ian j on 28/05/2017 19:16:03
tom hardy29/05/2017 00:26:54
30 forum posts
thank you ian j
i will try to make the suction hose this way does the discharge hose be the same as i think it lays flat
i am chasing the articles in model engineer so if you have copies that would be great
tom
ian j29/05/2017 08:15:36
337 forum posts
371 photos
Tom.
I have sent you a private message.
Ian
