Andrew Phillips 4 | 05/04/2017 01:38:58 |
30 forum posts 3 photos | Hi All, this really is a very friendly and helpful forum - I wish I had come across it years ago! I am making a damper rod for motorcycle forks from a length of 5/16 in 16Gauge tubing One end requires a 1/4 in threaded extension. I plan to make this extension (about 1 in) from 5/16 MS rod threaded 1/4 CEI 26tpi one end, with the other end turned to fit into the tube. I can either thread tube and extension piece 7/32 ME 32 tpi and further secure with loctite, or turn the end plain to fit the tube and braze it in place. I am familiar with threading, but it would be an interesting experiment to learn basic brazing. Which joint would be stronger - screwing or brazing? The joint should be as strong as possible but is not safety critical. Your thoughts? Thanking you in advance, Andrew |
Jon Gibbs | 05/04/2017 02:23:43 |
750 forum posts | Hi Andrew, This is just a thought but the weight saving of 5/16" 16 gauge tube over 5/16" solid is not that great i.e. ~36% according to my quick calculation. If strength of the joint is an issue why not just turn it all from 5/16 MS rod and then joint strength is no longer an issue. HTH Jon |
Keith Hale | 05/04/2017 07:26:41 |
![]() 334 forum posts 1 photos | Hi Andrew, For more info on brazing go to **LINK** Read it - load your printer - print it - and read again. Keep it by you. It will set you on your way to successful brazing with a clear understanding of what to do, why you have to do it and how to do it. Do it right and the joint will be stronger than the parent materials, You may not elect to use silver solder as your filler metal but a brass rod instead. No matter, the principles are identical. You are still brazing. If you require any further help, then come back to us. Keith |
Tim Stevens | 05/04/2017 10:22:45 |
![]() 1779 forum posts 1 photos | You need to consider the effect of the heat on both parts. The strongest braze is no help if the heat weakens the tube ... And weakens means more than just less tensile strength, it can have a softening effect, too. Cheers, Tim |
Andrew Phillips 4 | 06/04/2017 22:24:12 |
30 forum posts 3 photos | Hi All, thanks for your replies. I will probably go for the screw thread method for now but I intend to learn brazing - it will be my ngineering challenge for the coming autumn. Cheers, Andrew |
