Andrew Tinsley | 24/03/2017 12:13:19 |
1817 forum posts 2 photos | The title just about says most things. The lathe mandrel appears to be in excellent condition and I have a new set of white metal bearings. My scraping abilities were learnt off full size locomotive axle boxes and to say the least are not good for small size bearings! So hopefully any scraping can be kept to a minimum. Andrew. |
Jon Gibbs | 24/03/2017 13:27:40 |
750 forum posts | Hi Andrew, Have you seen this guy on YouTube? **LINK** He has some useful vids on the ML7. HTH Jon |
Harry Wilkes | 24/03/2017 14:20:34 |
![]() 1613 forum posts 72 photos | Posted by Jon Gibbs on 24/03/2017 13:27:40:
Hi Andrew, Have you seen this guy on YouTube? **LINK** He has some useful vids on the ML7. HTH Jon Hi Andrew, Jon Was just about to make the same suggestion Titanium 15160 make some useful stuff H |
Andrew Tinsley | 24/03/2017 16:31:53 |
1817 forum posts 2 photos | Thanks for the link. Not quite as helpful as I hoped. I have the old unhardened mandrel and a brand new set of white metal bearings. With this combination, I expect to have to do some scraping, also I have this awful feeling that the finished combination will probably have a different centre height to specification! Andrew. |
Andrew Tinsley | 29/03/2017 12:16:04 |
1817 forum posts 2 photos | Hello again, I am still unsure of how do this job. Do I simply put in the new white metal bearings, then put the mandrel back and shim the headstock top retainers, until I get a smooth turning of the mandrel, without it binding up? Does one then use engineers blue and scrape the bearings in? I have seen that people sometimes use a flat block and reduce the bearing half diameter to get a good fit. Seems odd to me as this will make the bearings none round and hence they probably will need scraping. I have one mandrel that is in visual good condition (i.e. no scoring marks). This doesn't mean that it has not worn undersize. Does anyone know what size the mandrel bearing surfaces are? I also have brand new white metal bearings. These are as rare as hen's teeth, so I do not want to make a mess of this job! So anyone that can make some helpful suggestions would be very welcome. Maybe this is a straightforward job for those that know, but I am a scientist and really not into the ins and outs of practical bearing fitting!! Andrew. Edited By Andrew Tinsley on 29/03/2017 12:17:41 |
