Motion problem
No motion in forward gear
David Bothwell 111/01/2017 12:21:57
204 forum posts
Working on a three and a half inch gauge 0-6-0 "Molly" I bought part built. When I acquired it it was running in both directions but there were no connnecting rods fitted. I have now fitted these. The engine ran OK as I was very careful measuring for the holes (they were laser cut rods) however after a few runs the eccentrics were found to have moved and were loose. So I drilled and pinnned these. Since then the engine will only run in reverse!? I also noticed when I first (acquired) ran the engine the reverse lever seems to be the "wrong way round" i.e. when pushed into forward the engine runs in reverse. Any suggestions gratefully received. I should add the right hand eccentric (viewed from the back of the engine) is 90 degrees in advance of the left.
JasonB11/01/2017 12:34:22
Sounds like one or more got pinned in the wrong place, How are the eccentrics positioned in relation to the crankpins, they should lead by 90degrees and a bit more so say 100deg to start with
David Bothwell 111/01/2017 13:36:36
204 forum posts
I never altered any settings of the eccentrics, so I assume they are in the same position as when the engine arrived, but having said that something is definately amiss!
Chris Gunn11/01/2017 17:26:18
459 forum posts
28 photos
David, could you have reversed the eccentric rods to connect to the wrong ends of the expansion links?
Chris Gunn
David Bothwell 111/01/2017 19:53:39
204 forum posts
Hello Chris. many thanks fir your input, I thkink you may be right, unfotunately I would have to drill out the pins I have inserted to put it right. Am I right in thinking you mean to turn the eccentrics180 degrees? On the drawings I am sure it said right hand eccntric leading the left by 90 degrees(whis is now where they are), but will check thisin the morning
