Rotary converter.
Andy Sproule29/09/2016 18:13:44
122 forum posts
35 photos
Has anyone on here built their own rotary converter 240v to 415 and could give some info?There is a guy on ebay selling plans Les Austin,who does not use a transformer,anyone tried this?
Muzzer29/09/2016 18:17:33
2904 forum posts
448 photos
There seem to be loads of them out there including quite a few Youtube videos, so presumably not too challenging. Doesn't sound like something you'd need to be coughing up for...
TobaccoBurner01/10/2016 03:49:49
30 forum posts
I have done this successfully. Can’t provide details – never kept any notes but I can give a few pointers.
The need arose when I acquired, very cheaply, a Pollard high speed drilling machine that had a 415v 3 phase motor. Changing the motor would not be easy and a transformer + inverter would have cost far more than the machine but I did, potentially have the bits to make a rotary converter – to whit, a spare 3 phase motor with all connections available and a assortment of capacitors.
Most (all?) published designs based on ‘idler motors’ are 240Vin/240Vout or 415Vin/415Vout. I needed 240Vin/415Vout so:-
Question 1: Will a 415V star connected 3phase motor continue to run with just 240V applied to a single winding (phase to star point)?
Answer: Yes and the rotary transformer action gives a reasonably balanced 415V between phases.
Question 2: Is the current in the single winding reasonable – again yes.
Question 3: Can we get it to self start?
Answer: Not with the components that were to hand. It would start but not at the right speed.
This problem was solved by using a small single phase motor (again from the ‘come in handy one day’ pile) as a pony motor to spin up the idler motor before applying power to it.
So modus operandi:
Press and hold start button while pony motor spins up.
Release start button. This removes power from the pony motor and applies power to the idler motor (you need a few relays to do this sensibly).
Points to note:
All the output power is provided by a single winding in the idler motor so be mindful of the current rating.
The output voltages will not be perfectly balanced but this can be improved by adding capacitors between phases (bit of a select on test exercise).
As a final assessment the converter is actually bigger than the drilling machine but it does work and didn’t cost me anything. Hope this helps.
Andy Sproule01/10/2016 10:39:26
122 forum posts
35 photos
Mike I would have thought I'd have needed some sort of transformer to bring me from 240 to 415 good to know it can be done this way.I would have thought there would have been a lot more people on here who had made there own converter.
Muzzer01/10/2016 11:41:00
2904 forum posts
448 photos
That's an interesting and cost-effective solution. I'd hate to work out what the magnetics were up to, mind! It's not actually boosting the voltage so much as presumably generating the additional phases.
If I understand correctly, the machine motor has no neutral so the single phase power is only driving one phase of the idler motor. I'd love to see what the phase voltages and currents in the machine motor look like.
TobaccoBurner02/10/2016 03:08:51
30 forum posts
"cost-effective solution"
Probably only if you already have the bits.
"It's not actually boosting the voltage so much as presumably generating the additional phases."
Agreed. From what I recall my thinking went roughly thus:
Feed power to one winding and you have effectively a single phase 2 pole induction motor. Put crudely these work because the rotor becomes a 2 pole magnet which is dragged around by the stator field which keeps changing direction. Motors are also generators so we have a 2 pole magnet rotating inside a 3 phase stator. This is an alternator and since everything is vaguely symmetrical the winding voltages ought to be similar.
At this point the project went into 'suck it and see' mode and having achieved success further research and analysis went into the pending tray.
Obtaining waveforms might be difficult. I'm not sure I still have a high voltage probe and I certainly don't have a current probe. The last time I tried to get a current waveform in a power line using a small series resistor I forgot to remove the earth from the scope. Result - one destroyed probe and half the shop floor went dark. It's always the little things that get you.
It turns out I lied in an earlier post. I have found the basic schematic I generated for construction purposes and have uploaded a copy to my album. Treat with caution - e.g. no protective devices are shown.
