Clock spring is tired
Speedy Builder5 | 02/09/2016 10:44:10 |
2878 forum posts 248 photos | Question. Do clock springs get tired over time? I have a small 'kitchen' pendulum clock which has an 8 day spring and westminster chime (which is driven by 2 more springs, but not used or wound up). It has been running OK and keeping time, but has suddenly stopped. Its relatively clean, wound up and not overwound. I can't see an obvious blockage such as spider web or dead fly in the movement. I don't think that the inactive chime is stopping the main movement. |
Martin Kyte | 02/09/2016 11:05:52 |
![]() 3445 forum posts 62 photos | Oil the pivots? Martin
Speedy Builder5 | 02/09/2016 11:51:48 |
2878 forum posts 248 photos | Certainly the pivots are dry and we have / having exceptional dry and hot weather for the last 2 months (house temp 26deg C , Outside 37 deg. I am just cautious of over oiling. |
roy entwistle | 02/09/2016 11:54:10 |
1716 forum posts | Do NOT be tempted to try WD40 please |
Martin Kyte | 02/09/2016 12:12:13 |
![]() 3445 forum posts 62 photos | Add a little clock oil to the oil sinks with a cocktail stick then, unless you have a proper oiler. Start off with the escapement pivots, friction gets less of a problem the further down the train you go. regards Martin
roy entwistle | 02/09/2016 12:32:17 |
1716 forum posts | BobH On some chiming clocks there is a small lever near the 3 on the dial to stop either chiming striking or both Can you turn the hands forwards ( clockwise ) easily What time did the clock stop Don't force it Roy |
Speedy Builder5 | 02/09/2016 12:36:37 |
2878 forum posts 248 photos | 4:20 in the morning (It could chime on the 1/4 , but chime springs not wound up) - Seen the lever, and its free and didn't change the situation. It won't run even with the pendulum off at the moment, just a few tic tock and then stops. |
roy entwistle | 02/09/2016 12:52:41 |
1716 forum posts | BobH Though not wound up could still cause problems Wind both strike and chimes and see if it helps. A couple of turns will do. If you feel any resistance when moving the hands forward that indicates a part of the chiming mechanism binding |
Speedy Builder5 | 03/09/2016 11:23:35 |
2878 forum posts 248 photos | Interesting, A half turn winding of both the chime springs seems to have loosened things up with a bit of a chime. I will have to see how things go on. |
