Life of slitting saws
edintheclouds | 04/06/2016 20:45:22 |
50 forum posts 1 photos | Hi, Was I expecting too much from a new slitting saw? I've used a slitting saw for the first time today, it's 3" x 2mm x 64T, it was cutting BMS 3/4" deep x 1/2" thick running at about 800 - 950 RPM, lubricated with oil. The saw has become blunt before the end of the cut, would a larger diameter saw have been a better bet? Are there different grades of slitting saws available? Many thanks for any advice. Just uploaded photo of the set up. Les
Edited By edintheclouds on 04/06/2016 20:52:30 |
JasonB | 04/06/2016 20:48:33 |
![]() 25215 forum posts 3105 photos 1 articles | They are best run a lot slower than that, would you turn 3" stock at that speed on the lathe? |
edintheclouds | 04/06/2016 21:02:56 |
50 forum posts 1 photos | Thanks Jason, we live and learn. About 100 RPM? |
JasonB | 05/06/2016 07:25:08 |
![]() 25215 forum posts 3105 photos 1 articles | Yes.
Hopper | 06/06/2016 04:20:54 |
![]() 7881 forum posts 397 photos | Cutting speed rule of thumb for HSS when cutting mild steel is: 400 divided by the diameter in inches. So a 4" slitting saw would run at 400/4 = 100rpm. A 2" job would run at 400/2 = 200 rpm. So 3" should be good at 100rpm to be safe, or maybe up to 150rpm. Double these speeds for brass or aluminium. |
edintheclouds | 06/06/2016 09:28:38 |
50 forum posts 1 photos | Thanks Hopper, Your info is very useful, I will make a note for next time.
