Vic | 23/04/2016 10:35:38 |
3453 forum posts 23 photos | I bought some 12mm bright mild Hex stock from a local supplier and I'm not that impressed with the quality of the form. Only a couple of the " corners" are sharp the remainder being quite rounded. Is this common enough or is the stuff I have sub standard? It a shame as it turns really well. |
MyrtleLake | 24/04/2016 21:08:00 |
12 forum posts | In my experience, all standard (i.e. not precision ground) hex stock has rounding of the points. That is to be expected. How much rounding can vary, but the overall effect should be a nice, deburred corner. Something that drastically changes the overall hex profile is unacceptable. I might also add this. All the hex stock I've encountered has a uniform rounding of the points. Your description implies a fairly dramatic variation. That, I would find very odd and could be grounds for refusal. Definitely worth a point of inquiry, IMO. Edited By MyrtleLake on 24/04/2016 21:12:41 |
Vic | 24/04/2016 21:38:58 |
3453 forum posts 23 photos | I only bought a metre of it but point taken, if I buy any more I'll inspect it a bit closer. |
