Rainbows | 13/04/2016 23:20:26 |
658 forum posts 236 photos | I saw an advert for an old lathe somewhere where the belt pulley was said to be mounted on a ball bearing which was then mounted on the spindle to "remove sideways belt force" (or something like that). Is this a real machine design option or was it some gimmick to sell an otherwise ordinary lathe? |
Paul Lousick | 13/04/2016 23:34:14 |
2276 forum posts 801 photos | Many "old lathes" use flat belts and the pulleys are crowned to keep the belt centered. It is possible that the crown has worn down and the pulley is flat, causing the belt to slip off. A ball bearing could be used as a wheel on the edge of the belt to keep it aligned. If the pulley crown has worn away it could be an indication that the rest of the lathe is also worn. Paul. |
John McNamara | 14/04/2016 00:10:33 |
![]() 1377 forum posts 133 photos | Hi Rainbows I am sure there are other members that may remember other companies that did this. From Memory the German company VDF did this with one of their lathes? They also offered plain bearings for some of their lathes the objective being a finer surface finish. Even super precision bearings create some bearing noise that may affect the work finish. The Diamond turning lathes used to turn computer disks do not use ball bearings, Air or magnetic levitation bearings are used for mirror finish required. |
David Jupp | 14/04/2016 07:32:21 |
978 forum posts 26 photos | My Smart and Brown lathe has such an arrangement. I only know because the pulley bearings were noisy when I acquired it, so I had to strip it down to replace them. The spindle itself runs in its own bronze bush and paired angular contact bearings (which luckily were in good condition). |
Swarf, Mostly! | 14/04/2016 09:32:35 |
753 forum posts 80 photos | Surely this arrangement is quite common (standard, even!) in pillar drills? Certainly my Tauco works that way. Best regards, Swarf, Mostly! |
MW | 14/04/2016 09:53:43 |
![]() 2052 forum posts 56 photos | I've changed most of the things on my lathe but i won't touch the headstock, so long as it's in good order i dont want to open that can of worms! Michael W |
