This Engine has overhead automatic inlet valves and side exhaust valves and is equiped with water pump and givernor.
Four stroke Fred | 12/11/2015 06:47:07 |
![]() 322 forum posts 305 photos |
George. |
JasonB | 12/11/2015 07:49:16 |
![]() 25215 forum posts 3105 photos 1 articles | You got that one done quickly George, look forward to the video. Thanks for posting, J |
Muzzer | 12/11/2015 08:15:07 |
![]() 2904 forum posts 448 photos | Atkinson Cycle engines are in wide use in production cars, mainly for hybrid vehicle use (eg the Toyota / Lexus hybrids and others from Ford, Merc etc), including the original Toyota Pious. The BMW VANOS system almost does the same thing and requires very little throttle control to control the inlet charge, instead using valve timing to do much of the work. It's the std arrangement for most of the BMW gasoline engine range now. The car engines use variable inlet valve timing to control the inlet charge whereas the original Atkinson cycle engines had variable displacement and even opposed cylinders. What is yours? Variable displacement? Sounds interesting! Murray |
Four stroke Fred | 12/11/2015 08:25:06 |
![]() 322 forum posts 305 photos | Good Day Murray, The engine has variable displacement with different capacities for induction and expansion. I have made a single cylinder edition of this type of engine and it's great for displays as there is plenty to look at when it's working and most people haven't seen this type of engine before. What really gets them is when you tell them that the system was design in the 1880s and the designer didn't have a computer! George. |
Gas_mantle. | 12/11/2015 08:50:45 |
![]() 359 forum posts 269 photos | A great engine and something to be proud of. I like the flywheel, is it from a casting ? I'm interested mainly in steam engines but would love to be able to make wheels like that, at the moment with limited experience and tooling I struggle to make an attractive looking wheel. |
Four stroke Fred | 12/11/2015 09:29:50 |
![]() 322 forum posts 305 photos | Good Day Peter, The flywheel is the one casting I didn't make. I think it may have been a shell mould casting. It was given to me many years ago in return for a job I did for some one. It's a great casting in bronze and I have been waiting for the "right" job to use it on. I am hoping that this engine will run at steam engine speeds (quite low) as that will enable the action to be seen. Thanks for the comments. George. |
Gas_mantle. | 12/11/2015 09:39:49 |
![]() 359 forum posts 269 photos | Thanks George, its a great little engine and the wheel suits its style nicely. I look forward to hopefully seeing it running |
