Copper boiler
Mark Salzedo | 31/10/2015 09:55:45 |
49 forum posts 4 photos | Hello, I have a coal-fired copper boiler which has been painted black, not particularly well I would hasten to add. Will it be in order to remove the paint with 'Nitro Mors'. Will this product adversely affect the copper and/or bushes? Many thanks, |
Brian Wood | 31/10/2015 10:00:24 |
2742 forum posts 39 photos | Hello Mark, I can't see any reason why Nitro Mors would attack copper of bronze/brass based bushes. It will remove the paint as that is what is designed to do. so I say use it Regardfs Brian |
Mark Salzedo | 31/10/2015 10:08:03 |
49 forum posts 4 photos | Hello Brian, Thanks for that. I just wanted to make sure before I take the plunge. Regards, Mark |
Mark Salzedo | 31/10/2015 10:12:36 |
49 forum posts 4 photos | Brian, It is a lovely old boiler built by Alec Farmer in 1966. It is 6" diameter and stands about 13" tall with about 40 tubes. These boilers were built to last. Regards, Mark |
HomeUse | 01/11/2015 16:30:03 |
![]() 168 forum posts 12 photos | If you have not used the stripper yet - make sure you soak the stripped boiler in warm soapy water after using the “mors” and then washing well in clean water |
