Mastiff Engine part 4 - off centre tappets to cams
Jeff Dayman08/09/2015 18:25:55
2356 forum posts
47 photos
Note for Mick Knights re his Mastiff Engine - part 4 article
It could be that the intention of the designer for having the tappets / cam followers offset to the cam centre was to induce tappet / cam follower rotation. This was done on some production flathead engines many years ago to equalize the wear and to spread the oil around on the tappet shaft.
Just one explanation - there may be others. Cheers JD
mick09/09/2015 09:48:37
421 forum posts
49 photos
Hi. Jeff.
Sounds like a plausible explanation. When I spoke to Kirk at Hemingway kits he told me it was an intentional part of the original design, but I was a bit too far down the line to carry out remedial work. Perhaps a note on the drawings to alert builders not using, or without the build notes to the different in hole centres on different components, but there again we are only talking a sixty forth of an inch on the original scale, which shouldn't have too much detrimental effect in the greater scheme of things.
Regards.
Mick
François GASPAROUX29/10/2015 09:35:13
3 forum posts
For Mick Knights
Help !
I am French and I am very interested in the construction of the Mastiff following your plans in MEW. Unfortunately I can not find your plans. Hobbystore does not have it. How to buy your plans?
I bought the plans of Masson in Hemingway, but I would like to have yours.
Excuse my bad English ...
François
Jens Eirik Skogstad29/10/2015 10:44:12
400 forum posts
22 photos
Not only side valve engine, I've seen both OHV, OHC and DOHC has tappets slightly off center of the camshaft. The purpose is to get tappets to rotate and get even wear without gnaw directly on the surface. It contributes to the longevity of tappets. smiley
mick29/10/2015 13:37:32
421 forum posts
49 photos
Hi Francois. Your English is better than my French! The plans are from Hemingway kits, I've just multiplied each dimension by 1.5 to give the increased scale.
François GASPAROUX29/10/2015 19:53:48
3 forum posts
Hi Mick
Thanks for your reply
I have Hemingway plans
what I do not see, is how to assemble the 2 halves of the krancase: it has not much material to drill holes for screws to secure the halves ! And there are oil ways ...
François
mick30/10/2015 10:23:16
421 forum posts
49 photos
If you are using the castings (original scale) then the crankcase is in one piece and I assume with all the internal features. If your making it from stock then there's no way you can machine the internal detail of the camshaft gallery without leaving the cutter radius in all the corners, you will also need long series cutters. I'm afraid you'll have to wait until the series reaches the stage when I tackle the assembly and the oil supply as its easier to show this with photographs. I do take the oil supply around the engine using external pipe work and the oil enters the engine from two ports on the sides at either end of crank case. The crankcase is held together by long series cap head screws, but you can't put these in until the oil ways and other features have been established. I used extra screws along the camshaft cover and the flange at the flywheel end for added strength. The two halves are finally secured using JB Weld, with all mating faces having a keying channel machined in them. Hope this helps.
Mick
François GASPAROUX30/10/2015 11:55:58
3 forum posts
Hi Mick
thank you, I understand better. I will actually waiting for the end of the articles.
I do not use the casting but I use a scale of 1.26 to easily convert in metric (inches multiplied by 32)
Thank you very much
François
