ML7 Headstock belt guard rattle (missing rubber bush?)
Trevor cartwright 104/08/2015 10:53:41
1 forum posts
Hi guys, the headstock guard on my newly aquired ML7 gives off quite a rattle when in use.
I've looked over the parts diagram and I think I'm missing two hard rubber bushes (part A1227)
Can anyone confirm that part A1227 would actualy stop the headstock guard from rattling?
Enough!04/08/2015 21:38:49
1719 forum posts
Posted by Trevor cartwright 1 on 04/08/2015 10:53:41:
So does mine ..... you mean it's not supposed to? smiley
Robbo04/08/2015 21:51:13
1504 forum posts
142 photos
Trevor
The sides of the belt guard that slide over the countershaft swing head assembly run on the rubber bushes and are a tight sliding fit.
If you look closely at the parts diagram you will see that the bushes are a "top hat" shape so bear on 2 sides of the guard sliding edge.
So the bushes do stop rattling.
The problem nowadays may be getting hold of some bushes. They can of course be turned from some plastic material.
Phil
