Question on a published artikel
Raymond Hodges | 15/04/2015 11:14:04 |
71 forum posts 1 photos | Hello In the MEW 117 July 2006 is an artikel on "A simple spark erosion Machine", in the circuit for the Oscillator is a switch S1 with R1-R2 and another Switch with R5-R6and R7 Are these switches two separate switches or a single xpole, and would it be posible to replace them with Potentiometors. My knowledge of electonics is veryy limited. Thank you for your answers Ray |
Steambuff | 15/04/2015 11:36:17 |
![]() 544 forum posts 8 photos | Ray, It looks like 2 separate switches as they provide different functions. I would not replace them with a pot, but if you did you would need to insert a resistor in series with it to provide a minimum resistance.(equal to the lowest value of the current ones) Dave |
Raymond Hodges | 15/04/2015 12:36:39 |
71 forum posts 1 photos | Thank you Dave I'l keep that in mind. I wasnt sure if it was 1 or 2 swithes, i hadnt grasped the 2 different functions. Ray |
andrew winks | 15/04/2015 12:43:17 |
![]() 117 forum posts 1 photos | This technology has always been of interest to me. Is there a design out there that are better than the others. Recommended reading? Cheers, Andrew |
Les Jones 1 | 15/04/2015 13:01:48 |
2292 forum posts 159 photos | Hi Andrew, Les. |
Raymond Hodges | 15/04/2015 13:07:05 |
71 forum posts 1 photos | Andrew try the web site www.mikesworkshop.weebly.com, you will find a spar eroder under Miscellaneous. This is where i started, the site is from Mike Cox Good Luck Ray |
andrew winks | 16/04/2015 10:42:40 |
![]() 117 forum posts 1 photos | Many thanks. Les and Ray. |
Les Jones 1 | 16/04/2015 17:35:23 |
2292 forum posts 159 photos | Hi Ray, Les. |
