Andrew Entwistle | 14/04/2015 10:58:54 |
![]() 120 forum posts 218 photos | Hi, I have just started construction of the Hemingway Ransome Mill engine and when setting up the flywheel on a faceplate I noticed that there is quite a runout on the inside diameter of the rim with respect to the rim outer, groove and the hub. I wonder is this intentional to provide balance weight against the reciprocating action? There is no mention of this in the drawings or in the ME construction article from 2001. Andrew. |
JasonB | 14/04/2015 12:25:46 |
![]() 25215 forum posts 3105 photos 1 articles | I don't think it is designed to be balanced. Its usual to set the INSIDE of a cast flywheels rim to run true as that is the hardest part to clean up and then machine the rim and bore to suit, in a bad case the outside of the hub may also want a quick pass to clean that surface up. At least thats the way I always set them up. J |
Andrew Entwistle | 14/04/2015 13:50:27 |
![]() 120 forum posts 218 photos | Thanks Jason, it is reassuring to hear that the eccentricity is not likely to be to do with balancing - because I have already machined the inside of the rim true to a profile using a silver steel form tool and the rotary table! I think this approach was unavoidable because the inside was simply not round. I did a quick calculation of the mass of the eccentric material removed as around 20g which only represents about 4% of the rim mass of the 7" flywheel. Andrew. |
