Eccentric Straps & Rods
Machining eccentrics straps and rods
Nick Campitelli12/04/2015 02:25:16
14 forum posts
I am making both a stationary mill engine & a G1 engine. I notice that the eccentric strap and rods are often made separately and the joined. Is there any reason why they can't be made in one piece?
Often, the strap is made of brass and the rod of steel but can't see any reason seeing as both ends then run on a bearing.
JasonB12/04/2015 07:09:04
No reason that you can't make them from one piece, infact a lot of smaller models have the strap/rod as a single gun metal casting.
A steel rod would be more typical of full size where economy would dictate the use of steel for the rod and also stronger for the same section of material.
I'd rather make the strap from bronze or cast iron rather than brass as they have better running qualities
J
Bob Youldon12/04/2015 22:35:27
183 forum posts
20 photos
Hello Nick
I'd suggest you make the rod and strap in steel and in one piece, make the eccentric from a piece of cast iron or drawn bronze and if you get a good finish on the running surfaces, with a drop of oil it'll go on for years.
Bob Youldon
Nick Campitelli17/04/2015 07:26:16
14 forum posts
Thanks Jason & Bob - Good food for thought.
Thanks,
Nick
