What's the difference?
Exmoor309 | 26/02/2015 19:55:49 |
![]() 25 forum posts 5 photos | Hi all, Can anyone tell me what the difference is between Northumbrian and Rainhill? I've acquired some castings for Rainhill but I'm led to believe the design is filled with endless errors! Cheers, |
Bob Youldon | 26/02/2015 20:23:02 |
183 forum posts 20 photos | Hello Exmore I didn't think there was much difference, Northumbrian was described in ME a few years ago and probably most of the errors in the Rainhill design were engineered out and renamed. We had a Rainhill at Beechhurst which would occasionally thrash round with one up, but frankly I'd pop the castings in the sales section or the evil fleabay; you'd do a lot of work for little gain. Regards, Bob Youldon |
Exmoor309 | 26/02/2015 20:40:49 |
![]() 25 forum posts 5 photos | Hi Bob, Thanks for your reply. What would you suggest otherwise to build? Regards |
Bob Youldon | 26/02/2015 23:40:32 |
183 forum posts 20 photos | Hello Exmoor, The answer really revolves around several parameters, what skill do you have, you don't need to be a time served engineer, would it be your first project, what machinery, lathe, drill, mill etc; I've always built steam locomotives and if you fancy something like that, that isn't too taxing and will give years of pleasure then I'd suggest LBSC's Maisie, fairly straightforward, hundreds built, castings and materials readily available not to mention drawings and importantly a build manual, everything you would wish for and when completed they are easily driven and fired and on the track it will keep up with the big boys, they're a game little locomotive and will do all and a bit more on the track. I'd suggest you have a look on the Internet and youtube for LBSC's Maisie and you'll see a good number of examples. I would also suggest if you aren't already, join your local ME society, a very valuable resource and not to mention, a good supply of tea! Regards, Bob Youldon |
