Sizes of Injectors
John Andrews 2 | 24/12/2014 02:14:33 |
22 forum posts | G'day,
I am building a 5 in gauge loco. Boiler is 150mm dia by about 800 mm long. Cylinders (2) are approx 42mm dia x 56 mm stroke. Drivers are 109 mm dia. I wish to fit two injectors. Can anybody recommend what size they should be? Can anyone recommend injectors that actually work? I have tried two separate types (different makers) in my Marie E, and neither work. |
Nigel Bennett | 24/12/2014 11:22:40 |
![]() 500 forum posts 31 photos | A couple of the "Standard No.4" jobs should deliver enough - or fit a No.3 and a No.4. You can probably leave the smaller one on a lot of the time that the loco is working fairly hard. Your failures on the Marie E may be nothing to do with the injector itself; a number of possibilities can be as daft as fitting it the wrong way round, or inadvertently missing out or mixing up the delivery/steam cones! Other possibilities are inadequate steam supply, contorted delivery pipes, insufficient throughput of the boiler check valve, leaking check valve, too hot a water supply, restricted water supply....I would eliminate all those possibilities first before condemning your injectors. If it still fails, you need to try it out on somebody else's loco with a working injector - or at least borrow a known-to-work one first. |
Steamgeek | 24/12/2014 12:06:34 |
45 forum posts 4 photos | Don't forget a leaky pipe or worn valve that allows air into the line, injectors are not particularly tollerant of air in the water supply. I run 2 no4's on a three cylinder loco and find them more than adequate, and a single no4 on a Torquay Manor which also does the job |
