Oops! Blunt a tool the easy way.
Neil Wyatt16/12/2014 17:39:51
19226 forum posts
749 photos
86 articles
Just spotted this and thought I'd share a pic.
This is what happens when you are in a hurry to get rid of some material and forget to change to a carbide tip.
It would have helped if I'd made a better job of grinding the top as well... must have been in a REAL hurry!
Breva16/12/2014 21:41:22
91 forum posts
7 photos
Neil,
Will need a bit of grinding there!
Can a carbide tool of similar shape to yours be got for a tangential tool? Would it work?
Andrew Johnston16/12/2014 21:47:50
7061 forum posts
719 photos
Turn it through 180° and grind the facet the other way; doesn't waste so much material.
Neil Wyatt17/12/2014 12:22:42
19226 forum posts
749 photos
86 articles
Hi Andrew,
A 180 degree turn would mean extra grinding, because the angling of the toolbit is about 10 degrees, the top needs to be ground at about 20 degrees (that one isn't really ground at enough of an angle).
Indeed, I may remake this (version 4...) with 12 degree clearance angles.
