Wheel set up.
ANDREW JACKSON 5 | 01/12/2014 21:25:45 |
3 forum posts | I have just my first metal turning lathe (Myford ML10). Is there anyone that can tell me the wheel set up that will engage the auto feed. I have watched a video on YouTube and the set is different to what's on mine. On the video it shows 4 large wheels on mine there are small ones that do not engage the top drive wheel so the auto feed does not engage. |
Engine Builder | 01/12/2014 21:31:39 |
![]() 267 forum posts | Hi Andrew, You need a set of gears to connect the leadscrew to the spindle. These would have been supplied with the a new lathe. By using different size gears it will give a different feed rate. The gear chain needed for different feeds should be shown inside the gear cover. Sound like you do not have these. |
Martin Cottrell | 01/12/2014 21:57:25 |
297 forum posts 18 photos | Hi Andrew,
TrevorK | 01/12/2014 23:12:53 |
45 forum posts 4 photos | Andrew I have sent you a PM, see your Inbox. Trevor |
