Lidl Portable Bandsaw
Ady111/01/2021 18:47:30
6137 forum posts
893 photos
This only created a new problem, the tyre would now come off under load since it was no longer seated on the drive wheel dimples
To the rescue came my old friend, pinkgrip. I lifted the tyre all the way round and filled the inside gap with it
Then put a bit onto the 5mm belt raised side just for luck, so the green belting stayed in the groove
Left it for nearly 3 days to cure
Put it back in today with a new blade and the band stays on fine, which was the great unknown here
There are no weird noises from the bandsaw and the blade sounds a lot happier
The cut also looks nicer than previously
Other notes: The drivewheel nuts were seriously tight and it took a good bit of effort to get them off
I ground the internal cleaning brush down to fit the new angle of the revolving blade
The drive wheel guard didn't really need removed
The album for the mod is here
Only time will tell now whether this has been worth the effort, will keep you posted
Edited By Ady1 on 11/01/2021 19:13:04
Edited By Ady1 on 11/01/2021 19:17:01
