advice
Trevorh | 22/02/2012 17:48:31 |
![]() 316 forum posts 89 photos | Its a glue Jason B put me onto - it is a glue that bonds Metal and disimilar materials but not as strong as some epox glues or Loctites I use it to fix any small or delicate parts onto larger metal pieces which then allows me to perform Light machining, you can get it from screw fix and even some of the larger Tesco stores
what I like is that after the machining you can break it away and lightly scrape the adhesive off |
Trevorh | 22/02/2012 17:51:40 |
![]() 316 forum posts 89 photos | Hi Les, This method worked really well but I think I am also going to make a set of square and hexagonal blocks as David described - i think they can be really useful as a means of holding the small parts that will need drilling for split pins and so on I must admit that when I first fitted the Tee slots to the top slide extension I didn't think I would ever need them Just goes to show Cheers - until the next problem
ChrisH | 22/02/2012 18:16:13 |
1023 forum posts 30 photos | Hi kerbtrawler, thanks for the info, i must slip along to screwfix and get some! |
JasonB | 22/02/2012 18:22:11 |
![]() 25215 forum posts 3105 photos 1 articles | Was not me, never used the stuff. Was it their PU which looks like golden syrup or their superglue? I use Titebond PU adhesive when I need it. |
Trevorh | 22/02/2012 19:20:55 |
![]() 316 forum posts 89 photos | Hi Jason, Sorry about that I was sure it was you, either way it works really well, its the one that looks like syrup and sets white, but needs to be ideally forced together to go off correctly cheers |
Trevorh | 08/03/2012 15:35:53 |
Posted by David Clark 1 on 20/02/2012 15:23:40:
Hi Kerbtrawler. Put the bar in the vice, squaring up with a square. Drill undersize halfway through, turn the bar and block over, drill through from the other side. Drill through the collar, from both sides if neccesary. Assemble both parts and open up to finished size. regards David
Taking Davids idea a little further I have now made several square bars to hold the various pins for the front end assembly - it makes drilling the 1/16" holes for the split pins so easy and all 5 have come out straight and parrallel |
Les Jones 1 | 08/03/2012 16:46:12 |
2292 forum posts 159 photos | Hi, Trevorh, I have just realised that I was calling you "Kerbtrawler" in my previous replies. I apologise for my error. Les. |
