Al 7075-T6 for Unimat saddle gibs?
old mart | 11/06/2023 19:03:41 |
4655 forum posts 304 photos | We have just made a brass gib for the longer cross slide on the Atlas 12 x 24 lathe, it was the best size laying about and quite good. The original looks like cast iron, and if I had a choice some bronze woulf have been used. The aluminium might wear faster, but if it is available and can be adjusted easily, I see no reason not to use it. Keep the bed clean and oiled and all should be well. |
Julius Henry Marx | 11/06/2023 20:55:20 |
113 forum posts 52 photos | Hello: Posted by Huub on 11/06/2023 14:12:37: ... "scraped" the saddle of both my lathes. | ... diamond dremel disk ... | ... sanded the high spots on the saddle (not the bed) only the flat side, not the V shaped side! You sir are undoubtedly both a brave (and knowledgeable) soul! 8^D ... measured the tilt on the saddle edges using an indicator and stopped sanding when the indicator did not move when I pressed on the edges of the bed. I used the sharpy method to find the high spots. Interesting. (warnings have been taken into account ...) After sanding with the Dremel diamond disk, I sanded the sides using a 1000 grid paper. Am I correct in assuming you are measuring the 'tilt' from/between front to/and back? I think that is the hardest part to get right. Could the milling column vee block (on the back of the bed) be used for the magnetic base? ... time consuming but "easy" job and it will improve the rigidity and accuracy of the lathe. It is also the first thing to do before aligning these parts.I did the same with the head stock and tail stock of both my lathes. When I am through with all the pending stuff I will have a go at the measuring part of the procedure to see exactly what is going on. Not having a reliable idea of the situation is a sure recipe for going around in circles. Thank you very much for your input. Best, JHM |
Huub | 11/06/2023 21:56:13 |
220 forum posts 20 photos | Posted by Julius Henry Marx on 11/06/2023 20:55:20:
After sanding with the Dremel diamond disk, I sanded the sides using a 1000 grid paper. Am I correct in assuming you are measuring the 'tilt' from/between front to/and back? You can measure the tilt using an indicator but you probably feel the headstock/saddle/tail stock rocking when pressing on one of the four corners. Weep off any oil because that influences the measurement.
I think that is the hardest part to get right.. The hardest part to get right is the head stock alignment. Once the head stock isn't rocking any more, you can adjust the alignment. For that you have to remove metal on two places so the headstock doesn't start rocking again. Because you don't remove much metal, It is a slow process so it takes a lot of trials to see a change in the alignment. That also means that if you remove the metal on the wrong side, you only slowly increase the error. Once the headstock is aligned, you can align the tail stock. If you bolt your lathe to a rigid stand, you can twist the lathe bed causing mis alignment. So my mini lathe and bigger lathe are not bolted to the stand. |
Hopper | 12/06/2023 04:32:48 |
![]() 7881 forum posts 397 photos | Posted by Huub on 11/06/2023 21:56:13:
If you bolt your lathe to a rigid stand, you can twist the lathe bed causing mis alignment. Not if you do it correctly and put shims under any of the lathe feet that are not in contact with the base before tightening down any of the bolts. Here is a description from the Myford manual on how to do it, and how to use a dial indicator to make sure there is zero distortion of the bed when bolting it down. See Fig 19 and text below that. |
Julius Henry Marx | 15/06/2023 02:48:45 |
113 forum posts 52 photos | Hello: Posted by Kiwi Bloke on 11/06/2023 02:08:13:
... the mating surfaces of the underside of the saddle held the 'lift strips' a tiny bit away ...
I think that the original topic ie: question about lift plate material has been answered and it would be a good idea to split this post to another, related and equally important topic. I went to my usual purveyor of plastics and non-ferrous materials today and got a very good deal on a few left over bits and pieces, one of which was a length of 5/8" x 5/32" brass, more than enough to make myself a new pair of lift plates to replace the ca. 1980 Emco issued ones. Then I started on Kiwi Bloke's suggestion which I think merits its own thread. Thank you all for your input. Best, JHM Edited By Julius Henry Marx on 15/06/2023 02:50:36 Edited By Julius Henry Marx on 15/06/2023 04:14:02 |
Hopper | 15/06/2023 08:40:29 |
![]() 7881 forum posts 397 photos | Fitting of the strips seems related to the choice of material. Bit of brass should work for you. I vaguely remember on one "microlathe" I fixed up for a bloke a few years ago it did perform better when we set up the lift plate strips (steel from memory) so they were a neat sliding fit on the underside of the way where they run. Blued them up to just contact and that is all. Had to rub a few high spots down on the ways with a fine flat file and rubbing stone. In theory the lift plate should not affect cutting but in practice it did seem to help on these rigidity-challenged tiddlers. Edited By Hopper on 15/06/2023 08:40:53 |
Michael Gilligan | 15/06/2023 10:41:14 |
![]() 23121 forum posts 1360 photos | Posted by Hopper on 15/06/2023 08:40:29:
[…] In theory the lift plate should not affect cutting but in practice it did seem to help on these rigidity-challenged tiddlers.
. I suspect that the lack of mass in the saddle and its attachments might be a major contributor to the problem … a big lathe has lots of inertia there, and the saddle is well-behaved on the inverted vees.
MichaelG. |
Graham Meek | 15/06/2023 11:29:17 |
714 forum posts 414 photos | The OP says he uses Carbide inserts. There is no problem with this provided the insert radius is not too big. I only use 0.2 mm radius inserts on my Unimat. Using a 0.4 mm rad causes a lot of vibration and a poor finish. The Compact 5 will tolerate the 0.4 mm radius with no problem. Having said that there is more contact area on the carriage. Plus the headstock bearings and spindle are more robust. It is all a question of rigidity with these small machines. The quality of the insert is another key player. They will seldom have as keen an edge as an HSS tool properly stoned. The Unimat machine was designed in the early 1970's and it was designed around HSS tools. This was the tooling that Emco originally supplied. Emco did not start supplying Carbide inserts for the C5 until the 1990's. Regards Gray, |
Julius Henry Marx | 15/06/2023 12:27:58 |
113 forum posts 52 photos | Hello: Posted by Hopper on 15/06/2023 08:40:29:
... seems related to the choice of material. I believe so. Having read more than one post on various forums where it was stated that the change to brass strips made a noticeable difference, I look forward to being able to say the same thing. Posted by Michael Gilligan on 15/06/2023 10:41:14:
... lack of mass in the saddle and its attachments might be a major contributor ... No suspicion whatsoever on my behalf: I'm absolutely convinced that it is the major contributor. Just the fact that a barely ill fitting set of lift strips will wreak havok to the simplest turning operation (eg: small diameter, short piece of plain aluminium) attests to that being so. Like I mentioned earlier in this same thread: " ... how much effort was put into limiting the type and amount of materials used (eg: underside of the carriage (!), lead screw nut post, etc.) I am absolutely convinced that accountants and not engineers were in charge." ... one of those “you can’t scale Nature” situations ...
If it were only that (ie: scale) then the U3 would have a saddle cast from the same material as the bed and it would have a size/weigh/heft in proportion to the size/weight/heft of the bed, like most lathes seem to have. Thank you both for your input. Best, JHM Edited By Julius Henry Marx on 15/06/2023 12:28:24 |
Julius Henry Marx | 20/06/2023 13:25:55 |
113 forum posts 52 photos | Hello: Posted by Julius Henry Marx on 15/06/2023 02:48:45: ... started on Kiwi Bloke's suggestion which I think merits its own thread. Best, JHM |
Julius Henry Marx | 20/06/2023 17:18:54 |
113 forum posts 52 photos | Hello: Posted by Graham Meek on 15/06/2023 11:29:17: ... OP says he uses Carbide inserts. Quite so. I purchased them sort of in a hurry, along with some much needed belting and tooling when I purchased my U3. ... provided the insert radius is not too big. I only use 0.2 mm radius inserts ... Ahh ... all the inserts I have are DCMT070204 / DCMT21.51. From what I have read, the '04' is the radius and yes, quite a bit of vibration on the U3, now greatly reduced after fixing the carriage lift strips but still singing a bit when turning. A question if I may: could you tell me what model/code inserts do you use with your Unimat? I see that the same manufacturer (Mitsubishi) also has a DCMT070202 on their webpage for that specific product, but there are 13 (!) different options. Ideally I would prefer to use that same shape as I already have a few holders. Thanks in advance. Best, JHM |
Huub | 20/06/2023 18:28:35 |
220 forum posts 20 photos | From Mitsubishi I use the DCMT070204 VP15TF inserts for steel. These are intended for finishing. DCMT070202 inserts have a smaller nose radius and will need less cutting forces. These inserts are also sharp enough for turning POM or brass. For aluminium I use the uncoated ground inserts from Korloy DCGT070204 AK H01. These are also available as DCGT070202. These work also for POM and steel because the cutting forces are low due to the very sharp ground cutting edges.
Kiwi Bloke | 20/06/2023 21:36:43 |
912 forum posts 3 photos | As Michael Gilligan has pointed out, scaling things can cause problems. Remember that, as linear dimensions increase, mass increases with a cube law. Even though a larger lathe can take heavier cuts, I don't think cutting forces, which have to be reacted by saddle, etc., will increase at anything like the same rate. Therefore, in large lathes, the saddle's weight is a major component of its location and stability. A little U3 is, one might say, too lightly constructed, and is not gorilla-proof, and nature's scaling law works against it. As Graham Meek has pointed out, the Maximat 11 has plastic anti-lift strips. I think the V13 also has. Neither is adjustable, IIRC. They probably contribute little to the stability of the saddle (under normal conditions). On the U3, however, the anti-lift strips are vital, because gravity isn't doing enough to locate the saddle. They are non-adjustable (unlike the Sieg - interesting...), and it appears that saddle manufacture has, in their location surface's regard, wide tolerances. This long preamble is to justify my belief that the choice of a plastic material by Emco is intelligent, not negligent. The strips are almost certainly designed to be elastic, so that they are in a sprung, pre-loaded condition when tightened down. Of course, when the saddle has been incorrectly manufactured (or horribly worn), there's no pre-load, nor even any contact, so they are ineffective. So the strips must produce a sufficient force on their ways to pull the saddle down onto the bed ways, doing the job that gravity can't. Lubrication in this position is going to be hit-or-miss, so an inherently 'slippery' plastic is better than metal. Also, the increased stiffness of metal means that it won't act like a spring. Sieg's adjustable strip approach is necessary for metal strips. Emco provide no adjustment, so flexible strips are necessary in this application. Metal may be OK, if carefully fitted, but wear will destroy the fit. Think in terms of pre-load. No movement is possible, until the pre-load force is exceeded, even if pre-load is provided by something floppy, like a rubber band! Bottom line - stay with plastic, but make sure it is adequately pre-loaded!
Julius Henry Marx | 21/06/2023 06:10:31 |
113 forum posts 52 photos | Hello: Posted by Kiwi Bloke on 20/06/2023 21:36:43:
As Michael Gilligan has pointed out ... Please see the reply in my other thread about carriage rigidity. Best, JHM |
Kiwi Bloke | 21/06/2023 06:58:09 |
912 forum posts 3 photos | OK, I took a guess as to which thread I should aim my reply - and got it wrong. (Life can be so confusing...). Please see other thread. |
Hopper | 21/06/2023 07:24:46 |
![]() 7881 forum posts 397 photos | Perhaps the mods should merge these two threads into one? |
